Question about Cameras
My screen says zoom error when i try to take a picture
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
Zoom error
It sounds as though your lens is sticking while trying to extend. Check the lens to see if it binds. Also look at the retracted lens and see if the center portion is properly centered or is cocked to one side and out of alignment.
Once your camera is working properly, as you say it does at times, hold the camera with the lens pointed downward and run the zoom in and out several times to see if there is dirt caught between the lens cylinders. Sometimes that will work any debris out.
May 20, 2010 | Fuji FinePix S2000hd Digital Camera
Zoom pictures lower than what see in viewfinder
That's normal...it's called parallax error because the view finder is not in the same plane as the lens. Why don't you use the LCD screen to compose your shots?
Feb 22, 2010 | Canon PowerShot A95 Digital Camera
Zoom error comes up on LCD screen when trying to take picture....
I had this error and did two things to fix it and am not really sure which worked, or it may have been both:
1) Charge your batteries or replace with high power (2700) type
2)Is there a bit of dirt stuck between the zoom bit and the body?
With my S1000fd, if I press the on/off while holding the zoom bit so it cannot come out fully, I get the "zoom error" message.
Hope this helps.
Mar 28, 2009 | Fuji FinePix S1000FD Digital Camera
My fujifilm S1000 keeps saying "Zoom Error"
same problem camera was dropped and have zoom error, since the lens and lcd are FINE i dont think it will be that much to fix
Mar 13, 2009 | Fuji FinePix S1000FD Digital Camera
Can't take a picture or zoom out
Lens needs to be removed and repaired. sounds like the plastic pin which is used as a guide for the zoom drive thread has broken (common fault) replace with a metal rod of the same size. I've replaced a few with parts from other camera drive gear pins
Jan 13, 2009 | Fuji FinePix A800 Digital Camera
Focus error appear on screen
i just help the zoom to get out with a thin screwdriver and now the "ZOOM ERROR" message disappear, but i have another problem. The camera does not show the target (what to shoot) on the screen. It shows ONLY pictures on card.
I tried everything, but the target i choose does not appear on the screen.
Dec 09, 2008 | Cameras
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Zoom error
Sounds like you have a problem with the optics of the camera.
May 07, 2008 | Fuji FinePix S7000 Digital Camera
Zooming in.
Your camera jumped out of gear. Open the front metal cover and disassemble all arm working with the main motor gear and try to reposition the red dot on the big gear with the small gear side by side. Presto now your camera is aligned. Place all arms back in order to your new alignment.you got your self a working camera. D: 3403 3404 mean error = some thing is block your lense and stopping the motored gear. For future referance don't drop the camera agian, next time it might be a expensive fix next time around.
Apr 26, 2008 | Olympus ? Stylus 500 Digital Camera
Cameras Logo
15 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
