Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
Toyostove 30 error code EE13
My toyostove keeps stopping and displaying EE13. If I turn it off and on it will go again sometime for a longer time but eventually stop again with EE13. I am in a rural location and unable to consult dealer. Any tips on fixing this? Thanks
5 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: help plese
On a toyostove EE13 is the burner thermistor.
On the Toyo you may have to have the dealer help you, as it could be something easy like a very cold day or more complicated as a main circuit board.
Sorry but, that's the only solution.
Posted on Mar 25, 2009
Buffalo12980
  • 625 Answers
SOURCE: Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Posted on Nov 10, 2007
  • 3 Answers
SOURCE: toyostove laser 30 has error code EE22
EE22 is a lock out code that keeps you from continuing to try to start the heater. This code usually pops up as the result of a problem with the fuel supply (i.e. no fuel, fuel sys obstruction, clogged filter, water frozen in line, faulty igniter), but could be more serious. To clear the code the easy way, unplug heater for at least 30 minutes. While you are waiting, check your fuel tank to see if you have fuel. Then check filter to make sure the element is not clogged and that there is no air or water (or ice) in the fuel line. If you find a problem with any of these things, correct it before trying to start heater again.
For the rest email me at toyofreehelp@yahoo.com
Posted on Nov 21, 2007
jluer40
SOURCE: toyotomi laser 30 error code 6
I disarm the Toyotomy and cleaned ou everything, then error 06 dissapear...
Posted on Aug 19, 2012
I have a toyostove laser 30 kerosine heater which was displaying an EE 8 message, a repairman came and replaced the blower moto, and it started running agina, but now is showing an EE 13 message which the...
EE13 is for the burner thermister, not the thermostat. It prevents the burner from overheating. It does not reset after it has opened an will need to be replaced. Perform a resistance check on the thermistor. It should be less than 200k ohms after preheating. If it isn't, replace the thermistor. If it is the problem could be the circuit board. Hope this helps. Let me know if you need more assistance. nitensheaterservice@earthlink.net
Oct 26, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Smells like fuel no error code, burner light flashes
Turn off the gas valve! Perhaps your pilot light isn't lit, or there is some other seepage.
Regardless, if you smell gas TURN OFF THE VALVE, or if it is leaking and you cannot stop it it is VERY dangerous and you may have to call the fire department. Be careful and act FAST!!
Apr 10, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Ee13
EE 13 Means the unit is trying to start in to cold of enviroment
You can trick the stove with a hair dryer
Run the dryer close to the brass Thermister located inside the unit. On the burner pot
Dec 30, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
My laser 30 quit working suddenly last weekend. It has given error EE2, EE6 and EE13. What should I do?
Get it tuned. Sounds like it is plugged up.
If it has been more than 2 years since the last tun-up.
Oct 07, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Help plese
Mar 25, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Stove is smoking bad!
Anderson,
You have a fuel leak if you can see the smoke. Stop using the unit until you find the leak. It may be at the back of the fuel sump. If so, you will need to take the unit apart to get to the fitting. Look also around the top of the sump and around the igniter. If you have a leaking sump valve you may be flooding the unit. Either way fix what going on before you use the unit again.
Keep us posted with what you find.
Tom Hawkins
hawkins111@gci.net
Mar 17, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a monitor 2200 that is reading ee 13. what does that mean?
EE13 on a Monitor is one thing. The same code on a Toyostove is completely different. A Monitor EE13 means there was no flame at ignition. On a toyostove EE13 is the burner thermistor.
On the Monitor I would check my fuel tank. On the Toyo you may have to have the dealer help you, as it could be something easy like a very cold day or more complicated as a main circuit board.
Tom Hawkins
Bethel, Alaska
Dec 26, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove l73
Try cleaning the fan blades, etc. Does the blower stop after a while and not start again? If there is no ignite at all, could you need to clean your stove. Especially the heat pot?
May 01, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove laser 30 has error code EE22
Oct 20, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
78 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
