Printer malfunction printer jams paper at rear. despite removing paper, jams again, then will not run at all and all lights flash. also jamming at front sometimes.
    Sergeant:
  • 279 Answers
What model printer is this? Does it jam in the rear every time, or do some papers get through?
I can't really give you any specifics on how to avoid the jam without knowing what brand and model of printer you're using, but as soon as you get me that information, I will find you a solution.
Posted on Dec 19, 2007
Light flashes 3 times
Which light? Orange? You probably have a paper jam or an obstruction in your paper feed path:
e.g.
Orange light blinking 3 times
1250/E17
Description:
The front door is closed.
Resolution:
Open the front door to allow prints to exit.
1300/E03
Description:
A paper jam has occurred during printing.
Resolution:
Locate and remove the jammed paper from the printer.Press the button on the device to continue printing.
1303
Description:
A paper jam has occurred in the rear tray.
Resolution:
Remove the jammed paper from the rear tray.
Derived from: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/
Apr 14, 2014 | Canon PIXMA iP3500 Printer
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
Top/first symbol is flashing ...
Hi
It refers to a paper jam. Follow the below steps
1. Open the cartridge compartment Remove the toner and inspect if any paper jam has occurred
2. Open the rear of the printer and inspect
3. Check the paper sensor in the middle of the fuser at the paper delivery part.
4. Turn off the printer and inspect if any sensor is malfunctioning
remove any paper pieces if found and try to turn off the on the printer.
DO RATE MY SOLUTION
Regards
Jul 07, 2011 | HP LaserJet P2015dn Printer
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I have a hp deskjet 3940 colour printer,there is paper jam error,so what i could do to solve the problem
Follow these steps :
1.1
Take out any paper that is not jammed. Remove the loose paper from the in and out paper trays to prevent any more paper from being pulled into the jam.
2.2
Open the cover of your HP laser printer. This will give you access to the inner machinery of the printer and should unveil the jammed paper. If you do not see jammed paper, you may have another type of malfunction.
3.3
Gently pull on the jammed paper. In many cases, it will come out easily.
4.4
Move the rotors on the inside of the printer by pressing the flashing button on the housing of the printer. This may help to loosen any jammed paper.
5.5
If the jam persists, unplug your HP printer. You'll be able to pull more firmly on the paper with the power turned off. Be careful not to rip the paper.
6.6
Attempt printing again. Refill the trays with paper and plug your printer back in to test its functionality.
Oct 30, 2010 | Office Equipment & Supplies
Symbol lit up but don't know what symbol means, I don't have manuel - begins with 2 dots :
The symbol with the 2 dots and what looks like a jagged line is the paper jam indicator. Open the paper tray and or front and back access doors to find and remove the paper jam. I the light still does not clear try turning the printer off then on to reset the jam indication.
Aug 20, 2010 | Lexmark E260 Laser Printer
My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
Hello.
You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
Sheet Feeder or Manual Feed Slot: Press the
paper button to eject any jammed sheets, then open
the printer cover and remove any paper jammed inside.
Press the paper button again to clear the error.
Hope this helps.
May 31, 2010 | Office Equipment & Supplies
Brother HL-2070N red "paper" light flashes after a paper jam
http://welcome.solutions.brother.com
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
298 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
