Question about Samsung 61" Slim-Depth DLP HDTV
The light is flashing on the lamp light? What does this mean?
    President:
  • 788 Answers
Most likely you need to replace the lamp. How long has it been since you replaced the lamp? There are more components involved in the lamp circuit, but the lamp is the first thing to check.
I hope that this helps you, if not please respond to this post.
Posted on Sep 29, 2009
INFOCUS IN102 PROJECTOR LIGHT BLINIKING
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Aug 02, 2017 | Cell Phones
Red power, blinking red temp
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Temp and lamp lights flashing
can you let the projector work well
if the projector projects the image,
does the projector light?
if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
you only need to reset the timer of lamp and to reset the timer of the filter,
menu-setting-advance-reset-the timer of the lamp
menu-setting-advance-reset-the timer of the filter
Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
Sony grand wega 3lcd light is flashing red 3 times
Three flashes is lamp cover/lamp position error, it means the lamp cover is not set right, or the lamp is not in the right position. There are two micro switches to detect the lamp position, and lamp cover. Please reset the lamp and the lamp cover (door).
Aug 01, 2017 | Sony Televison & Video
Sony kds-60a2000 power light flashes 5 times, no picture
5 flashes - Lamp Driver - (lamp driver faulty)
This is the error code that usually means the ballast (it is the power supply for the lamp) is bad.
SD TECH
Apr 20, 2012 | Sony KDS-60A2000 60" HDTV
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
TURNS ON THEN FLASHES GREEN FOR ABOUT A MINUTE THEN KEEPS FLASHING RED .WHATS WRONG?
Probable lamp failure, lamp won't turn on leading to red light to come on. How many times does it flash? 3 means safety switch bad, 5 flashes means lamp or lamp ballast failing.
Sep 30, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Just lost the picture and now the lamp light is flashing
If lamp light on Sony TV front start flashing that means Lamp is dead and need to be replaced.
Lamp replacement is easy and procedure would be written in user manual of TV.
Dec 20, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
3 flashing lights after replaing lamp
check the lamp connection and also to insure you have the correct replacement lamp for your model. as 3 blinking LEDs mean lamp may be defective.
May 25, 2009 | Samsung HLP6163W 61" Rear Projection...
Panasonic PT 50LC14 problem
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Samsung 61" Slim-Depth DLP HDTV Logo
140 people viewed this question
Henry  Thomas
Henry Thomas
