Question about Solis Palazzo Espresso Machine
Blowing circuit When my palazzo goes to actually brew the espresso it blows any circuit it's plugged into (I have a new kitchen so I know the outlets are good). My local (lame) repair center can't do anything because they can't order any parts. He said water is leaking within the machine which is causing it to short circuit. Where can he order the necessary parts???
  • 515 Answers
Most of the part in your machine is that Saeco use in thier machines, i think the boiler is the same.
Posted on Jul 16, 2008
New Treadmill blows ciruit breaker when turned on.
have the new tread mill checked under warranty as it should not blow breakers from new
Feb 13, 2018 | Weslo Exercise & Fitness
Solis palazzo not producing coffee
I think the blockage might be at the brew unit, remove unit and check the screen under the red o-ring, connected to that is the chute that leads to the espresso spout. That tube might be blocked, there are 2 screws holding that piece together, be careful when you remove them do not lose the spring and ball in the fitting. Clean tube and reassemble.
May 24, 2012 | Solis Palazzo Rapid Steam Palazzo Fully...
Solis Palazzo : turn on machine the brew group does not position it self to prepare coffee.powder coffee, coffee, and espresso lights blink. Brew group is not removable from machine. machine has had light...
Hi
This is for a Vienna but it should work for you Palazzo. It will help you get the brew group out and reset so you can reinsert it.
http://www.fixya.com/support/r2296970-brew_group_stuck_t_get_out
Aug 04, 2011 | Solis Palazzo Espresso Machine
Our Magic Comfort plus is 4 years old and it keeps blowing the gfi instantly when I plug it in. I have had this problem occassionally in the past and it resolves after one or two gfi trips. Now if tripo...
The problem believe it or not your gfi is warn out. I am actually surprised it lasted as long as it has and surprised it worked at all. Espresso machines use a huge amount of power when turning on compared to maintaining power. When espresso machines first turn on the take a huge surge of power to start heating up the elements. Normally you want to put an espresso on a circuit /outlet that is directly to your breaker that is at least a 20 amp breaker. By code kitchens and bathrooms, where an outlet is near water, has to have a gfi outlet, this is for safety for something plugged in near water so it will trip if accident happens with appliance near water. The bad news there not to good with high demand power appliances such as espresso machines. Yes , you can replace the gfi circuit, by turning off main breaker, unscrew gfi from wall, pull out, and undo wires, and copy exactly when re-wiring the new one. Then turn on main breaker again. NOTE: you can buy a gfi all most any home improvement center, lowers, home depot, ace hardware etc.... Think of a gfi kind of like a advanced in line fuse, they do wear out. BUT AGAIN, my advice is plug it in a outlet that does not have gfi and is on a main breaker of at least 20 amps if you have that opportunity to do in your kitchen area. Hope this helps you, thank you....... MIKE
Jul 26, 2011 | Saeco Magic Comfort Plus Espresso Machine
I have a Solis Palazzo machine. My question is:
HI When was the last time you descaled? This can have a temp lowering effect if you don't descale on a regular basis. Program you water hardness so its set on 4. This will tell you when you have to descale. Descals is not the same as cleaning. Its a special acid that disolves the deposits inside the boiler.
Jul 24, 2010 | Solis Palazzo Espresso Machine
Woke up this morning and the coffeemaker did not auto brew. Now it won't brew at all. Dead? Nothing happening.
For starters, try plugging something else into that outlet, like a hair blow dryer to make sure your circuit breaker didn't kick off for some reason.
If you have power there plug your coffee maker in again and see. if it works, great. If not, you are probably going to be money ahead to just replace it as the cost of shipping and a repair won't be much less.
Of course if it is less than a year old you may have a warranty on it which would make it worth contacting Cuisinart Customer Service.
Oct 02, 2009 | Cuisinart CBC-00FR 12-Cup Coffee Maker
Keurig coffee maker causes kitchen electricity to short out.
I'm not completely certain what the problem is because it's not displaying your whole subject (it get's cut off after electricity to...). However, if it is solving the problem by moving it out of the kitchen, it's likely that the problem that the circuit is overloaded. Coffee makers have a large current draw, as do many other kitchen appliances. If you plug too many of them into the same circiut and then turn them on, you will put too high a drain on the circuit and it will cause the the current to become unreliable and then, eventually, through the braker or blow the fuse to protect the wiring in the wall (to keep it from catching fire). If this is the case, you need an electrician to run another circuit or remove some appliances from your kitchen.
Sep 18, 2009 | Keurig B100 Coffee Maker
Kitchen GFI breaker goes off when machine is plugged in - off or on
NEED TO REPLACE YOUR GFI WITH COMMERCIAL 20 AMP GFI MOST KITCHENS ONLY HAVE 15 AMP GFI'S BECAUSE THERE CHEAPER AND ELECTRICIANS SCIMP ON INSTALLS. BUT NEC STATES 2 DEDICATED GFI CERCIUTS TO EVERY KITCHEN COUNTERTOP.
Oct 30, 2008 | Saeco Magic Comfort Plus Espresso Machine
Palazzo espresso machine
you have to wiggle the unit some old coffee get in there it have to come wiggle it thanks for using fixya
pierre
Feb 25, 2008 | Solis Palazzo Espresso Machine
Solis Palazzo Espresso Machine Logo
81 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
