Question about HP OfficeJet K80 All-In-One InkJet Printer
How to exchange the ink cartrige in k80 - HP OfficeJet K80 All-In-One InkJet Printer
2 Suggested Answers
  • 7 Answers
SOURCE: PUT NEW INK CARTRIGES AND THE LIGHT STILL BLINKS
You didn't say whether these new cartridges were HP original or knockoffs or remanufactured units. If they are HP original then that suggests a bigger problem. If they are the other types then try taking one out at a time with printer on. Then shut it off with only the one in its cradle. Then turn it back on...if the light goes out then the one you removed is most likely defective. If the light is still blinking then switch the cartridges and see if that turns out the light doing the procedure above. You should have either the 56 or the 57 not both in their respective cradles. If the light doesn't go out then you might try cleaning the electrical contacts in the printer with a cue tip and 91% alcohol or distilled water....just make sure the contacts get dry before retrying any of the above. If these are NEW (in warranty) HP cartridges then you can send back but try them one at a time to see if just one of them is defective. HP also has email support on their website and you might try calling their tech support but don't expect a lot of help...this is an old printer.
hope this helps.
Posted on Aug 18, 2010
My friend had a problem of his printer, cause the printer didnt recognize the ink... it has 6 colors epson ink. we dont know how to fix it... all the cartrige shows x
Is your friend use CISS. If so
Move Ink cartrige holder to cartrige change station.
Put off cartrige ( genuin or CISS) from carrage
Take a soft erager try to remove dry in or dust or waste everything smothly
reassemble the cartrige again
push top of the cartrige gentaly sothat it struck acurately.
Turn on printer.
I think you will get rid from your pprinter problem.
Thank you
Aug 21, 2011 | Office Equipment & Supplies
Canon MP 610 printer. Cartridges half full when forced to replace
well printers calculate ink, with printing jobs. If you exchange cartriges in the middle of these ( ex:you exchange cartriges about after 100 print jobs and the cartriges is 500 top) the printer dont know excatly the ink level, so gives these error on calculation, not exact ink level. so you need to take out and place again to reset cartridge counter.
Jan 16, 2010 | Office Equipment & Supplies
Dell 720 printer , new ink cartriges but prints blank pages
I know it sounds silly, but never underestimate the obvious.
Did you remove the plastic protectors from the cartridges?
Another solution maybe to return the cartridges to the store for an exchange. It has only happened once to me, but I exchanged the cartridge for another "new" one and it worked fine.
Good luck
-Carlos:
Jan 07, 2010 | Dell Inkjet 720 Printer
I CAN NOT PUT IN THE INK CARTRIGE IN MY DELL 810 PRINTER, CARRIGE IS BROKEN WHAT CAN I DO TO PLACE IT.
>> Dell All-in-One Printer 810 with 2-Year Advanced Exchange
Exercise your right to "exchange" it, if the 2 years has not yet expired.
Otherwise, it might be cheaper to buy a new printer.
Nov 06, 2009 | Dell All-in-One Printer 810 with 2-Year...
Color cartrige doesnt work. cartrige is in but says it's empty.I have the 5600-6600 series.I have a #1 cartrige in.is it wrong?
You should take it back and exchange it or read on below.
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the internet
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well
Aug 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer will Not recognize ink cartridge
Even OEM cartriges have a failure rate of 2%. Take the cartridges back for exchange.
Jul 02, 2008 | Office Equipment & Supplies
Hp photosmart c3180 just hooked up, new, comunicates with computer on all levels. print or copy will not put anything on paper, goes through all motions but does not put anything on paper, new supplied ink...
There is no reason for it not to print ink onto the paper unless it's defective or both carts are dried up. I would return it for an exchange.
Hope that helps...
Geno
Mar 27, 2008 | Computers & Internet
Hp K80 printer
I cleaned the vertical centerpost (you'll see it when the cartidge is out)with a small amount of acetone (nail polish remover) on a Qtip & it works fine now....must be some kind of circuit that needs to be closed and the ink on it kept it open....
Dec 19, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
Printer issue
I can only suggest that you should use genuine HP ink carts. Try all new carts and realign again. Hopefully it is under warranty. HP is good at exchanging.
Aug 02, 2007 | HP PSC 2175 All-In-One InkJet Printer
Telling me that the cover is open and cartridge jam.
Suggest you read your manual! Fax use standard phone line not internet connection!!!!!!
Mar 06, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
HP OfficeJet K80 All-In-One InkJet Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
