Question about Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air Gas Range
I am getting the F1-8 error code.
It starts beeping after the oven cools down. Starts with the "standard proofing" error, then moves onto a constant beeping with the F1-8 error code. This happened 9 months ago, and I had the control panel (I think) replaced, now I am having the same problem.
  • Anonymous Feb 19, 2008
    I also have the Jenn-Air JDS9860AAW. A couple of years ago, I had some water leak into the touch pad control and the alarm F1-8 appeared with some beeping. Now that I've read about the troubleshooting information on this page, what would you recommend that I do for my Jenn-Air? Should I replace the Control Panel Assembly (#AP 377523) and Harness Control/P9 (#AP 377635), OR should I replace the Control Panel Assembly (#AP 377523) and Harness Sensor/lock/probe (#AP 377686)? Thank you!
  • 51 Answers
F1 is a bad power relay board.
F8 is a shorted meat probe alarm (probe jack or the harness to the probe jack)
Posted on Jan 18, 2008
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
https://www.repairclinic.com/RepairHelp/FaultCodes/26/Range-Stove-Oven
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
Electronic panel malfunction
A F1 code on Jenn Air refers to a failure in the ERC (electronic range control). There is not a fix for it other than replace the control.
It looks like the part is still around if your model starts with JGR8850 that is. The price of the part is around $300.00 so.... not sure if it would be worth putting that into this, your call
May 08, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Nov 04, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Jenn air range model SCE30600B error code FC blinks with beeping noise. After resetting the temp down to 350 to keep from burning a pizza error code FC started blinking along with continual beeping. I have...
replace the entire range: Jennair does not know how to design, make, or program electronics. It makes steel boxes that provide heat but electronics - that's not within their ability. Buy a Kenmore or a GE and your beeping problem will go away.
Feb 03, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Error code
I have a jenn air range gas cooktop electric oven model # svd48600b the convection fan will not turn off and when you attenpt to use oven an error code F-3 appears and beeping sound what part is defective?
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jen-air gas range
Look on the back of the oven for a tech sheet. This will tell you what these codes mean. It may be the oven temp. sensor that is bad and they are easy to replace. Sometimes they check ok at room temp. but fail at higher temps. and will shut the oven down. The temp. sensor is usually in the upper left hand side of the oven and looks like metal probe about 6-8 inches long. Hope this helps.
Oct 01, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Jun 01, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air JGS8750 Gas Kitchen Range Logo
1,117 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
