Question about Canon PIXMA MX310 All-In-One Printer
How do I print from memory on a cannon MX 310?
jerome24
  • 57 Answers
SOURCE: Canon MX 310
my suggestion is try to reinstall your printers driver after you reinstall the driver diagnose the printer and try calibrate
Posted on Mar 22, 2008
SOURCE: reset mx 310
This really worked with my MX 310:  http://www.fixya.com/support/t378057-reset_ink_levels_canon_mx310
Posted on Oct 01, 2008
danmats
  • 195 Answers
SOURCE: I have recieved a fax and display says
check that printer is OK in doing a clean up process.
Posted on Oct 26, 2009
SOURCE: Error 5100 on my canon mx 310.
the 5100 is the carriage error and can be caused by 4 different sensors. First off the "Timing Strip" that passes through the back of the Carriage Assembly can be contaminated with ink spots and this needs to be cleaned. Open the cover and use your flashlight to examine the timing strip as much as you can see. You really don't have much access to this strip unless you remove the covers,..and doing that is considerable work. The other items that can cause this error are the sensor inside the carriage unit, the drive motor for the carriage asm, and of course the main logic card. However, 99.6% of the time it is the Timing strip which is easitly contaminated with splattered ink.
Posted on Apr 02, 2010
  • 15 Answers
SOURCE: is it possible to get the disc to install the Cannon Pixma MX310
http://www.soft82.com/download/windows/canon-pixma-mx310-all-in-one-driver/
just go to this link and clilck where it says "free download" at the top, this will install the driver on your computer, you don't need the disc. Hope that's what you were looking for.
Posted on Jul 28, 2010
I just purchased a DELL Inspiron .. running Windows 7. It says if I just plug in my Cannon MX 310 Printer/Fax that Windows will recognize it and set it up for me. I see that it definitely creates an...
I am sure that, you have not installed the drivers of that printer, because Windows 7 recognize most of the printers automatically however the printer and fax machine would start working properly the time you would install the printer drivers on your system and laptop, please let me know it works or not, so i can send you next update on it
Sep 28, 2010 | Canon PIXMA MX310 All-In-One Printer
Is it possible to get the disc to install the Cannon Pixma MX310
Jul 28, 2010 | Canon PIXMA MX310 All-In-One Printer
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
MX318 fails all fax functions
If you are using only one incoming telephone line, you need tro reset your printer at 'fax priority' position onn your printer. An MX-typr handicap.
Sep 20, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannon mx 310 error 5100 Says chck printr with alarm light flashi
heres the problem from service manual: error 5100, a error occured in your encoder signal, it list 4 things in the serice manual.
carriage unit. carriage motor, logic board, timing **** film.
ok my first thing i would look at is the film that runs directly behind the print head i would think it is dirty. just turn on printer and get print head to the middle and turn off machine, gentle move print head to one side and gentle clean the film strip with a cloth with a little metho on it, move print head to other side and clean other part of ****.
i reckon that will fix your problem its a common problem they tend to get a bit of grease on the timming ****.
Canon Tech
May 30, 2009 | Office Equipment & Supplies
Help
go to the following link, select the operating system and language for your laptop and download the driver and software.
http://software.canon-europe.com/products/0010491.asp
May 27, 2009 | Canon Office Equipment & Supplies
Black and white printing on Canon MX 310
there is in adjusting the seal the printer bookmark, seal grayscal stile. Search for in adjustment before printing
Apr 24, 2009 | Office Equipment & Supplies
Canon MX 310 Scan Problem
re-install the printer. or google the code
Apr 01, 2009 | Epson Stylus 2200 InkJet Photo Printer
Sending a fax directly from computer using Canon Pixma MX 310
With the document open, you click Print, then choose Cannon ...Fax.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
Jan 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
old marine
old marine
