Question about Kenmore 659 Electric Dryer
Kenmore Dryer model 110.62932100
My dryer runs fine but is not generating any heat. I suspect the heat element, but am wondering if it could be something more minor (moisture sensor . Is there a way to test the heat element before I replace it? Ideas on what else it could be?
    President:
  • 1,776 Answers
First, make sure that there is no ventilation issue and that the vent is clean and clear. If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Remember to disconnect the dryer from the power source before attempting any repair.Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 29, 2009
Two problems with Whirlpool Dryer
I would suspect the heating element. I bet you are asking why this clown is saying that when you already told him that on high heat it worked fine. SIMPLE! Your heating element is made up of five coils. For low heat your dryer uses two heating elements and for high all five. So if one or two of the heating elements are open and they happen to be the low temp dry setting ones, that would explain it. That model doesn't have the dryness sensor on it (according to my documentation) so the heating element is the most likely cause.
Hope this helps!
ImJustAvg aka Hal
Dec 30, 2011 | Whirlpool Dryers
My kenmore 600 dryer will not heat up, what could be the problem?
No heat problems are caused by several things.
First lets do the easy thing and turn off the Dryer CB by pushing it HARD to off and then back on. Re-test for heat.
Next try different cycles as in Air Fluff, Delicate, regular etc... Air fluff is no heat but see if it heats on other heat temp selections. If you get heat on a different heat selection then the problem is probably an open thermostat. If you still get no heat the most likely suspect is the heating element. If the heating element is fine then your looking at the motor switch or wiring as the problem. Component of last resort to replace is the timer.
At this time I suspect either a high limit thermostat or an open heating element.
Mond you since you did not include your complete model number this response if for an electric dryer. IF your dryer is gas respond with a model number please so I can point to other things that cwill cause a no heat symptom.
Thanks for choosing FixYa, Kelly
Aug 04, 2011 | Kenmore 600 6962 Dryer
Dryer runs fine but stopped generating heat yesterday
CHECK THE HEATING ELEMENTS, THEY ARE PROBALLY BAD, AND REPLACE
Apr 26, 2010 | Kenmore 63942 Dryer
My Maytag dryer Model MGE2400AYW is not heating. It runs fine but it is not heating and I was wondering if you knew what it might be. I was told it is probably the heating element but am not sure.
First, try resetting the breakers for the dryer in the house electrical panel--push off, then on. If no help, then the problem is likely internal to the dryer. Suspect the heating element or thermostat that controls the heater. Good luck!
Mar 15, 2010 | Dryers
I have a 80 series Kenmore dryer, runs fine...no heat. Help!!!
Your heating element is burnt out or a high limit switch has gone bad. I suspect that the element is out since it is hard to blow a high limit switch. To access the element you will need to remove the back of the dryer and in the bottom left hand corner there should be a box, or tube, that contains this element. It looks like a toaster element. To see if the element is bad you will need to run a continuity test or visually inspect this coil for any breaks. If there is a break you need to take the model and serial numbers to an appliance parts house for replacement.
Good luck on repairs hope this helped you some
Dave
Jan 20, 2010 | Dryers
Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Dec 24, 2008 | Amana Dryers
Kenmore dryer doesnt heat
Nothing you did wrong! Probably needs a new heating element. Prices vary by model. Call Sears/Kenmore parts center nearest you. Tell 'em you need a heat element for your dryer. Be sure to provide your dryer's model number.
Unplug your appliance first before attempting repairs! Safety first and always!
Dec 19, 2008 | Kenmore Dryers
Kenmore 659 Electric Dryer Logo
316 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
