Question about Fargo DTC515 Thermal Printer
Fan doesnt run on fargo dtd515 & printhead
Fan doesnt run on fargo dtc515 & printhead overheats melting ribbons...where can i purchase a fan?
4 Suggested Answers
SOURCE: Fargo c16 card printer
Try cleaning all the rollers.
Posted on Apr 16, 2008
  • 8404 Answers
SOURCE: Fargo DTC400 is giving me "INVALID RIBBON" error
I think you or your machine have answered your own question. The machine said it isn't going to use the 300 ribbon and that is that.
I dont have experience with your particular model but I can tell you a Ford starter will not start a Chevrolet automobile.
I think you should take the 300 ribbon back and get a 400. If they wont take it back, trade somewhere else.
So, what do you say?
a
Posted on Sep 23, 2009
talent_anand
  • 168 Answers
SOURCE: Where can I get the drivers for a Fargo DTC515 for
http://www.driverguide.com/
Posted on Jan 16, 2010
Bought a DTC520 and replaced Printer ribbon and now message reads " No Printer Ribbon Installed" Used Part # 86031 DTC500-YMCKO I powered down machine and started again, still NO Ribbon...
You have to check which ribbons are loaded.
Depending on that you have to select the appropriate mode in the driver else it'll keep giving this message.
Y = yellow
M = magenta
C = cyan
K = black
O = overlay
May be you don't have overlay loaded
Aug 15, 2011 | Fargo DTC515 Thermal Printer
I have a Fargo DTC 515 thermal card printer. It is jamming
Hi the jamming may be due to wrong size of your cards
Check the dimensions on the box
ar you sure it's a cr80 and not a cr79 they don't have the same length.
Jul 23, 2011 | Fargo DTC515 Thermal Printer
I am having problems getting my fargo 515 toinstall on my windows 7. I was told i can run the install in compatability mode and it'd work fine, but thats just not happiningf! Any ideas?
Fargo does not make drivers for Windows 7, and does not support it. You will need to go to the new models to have windows 7 supported.
May 16, 2010 | Fargo DTC515 ID Card Printer
I have a persona C30 card printer by Fargo and it keeps telling me that the ribbon is broke when in fact it isn't....I put in a new ribbon cartridge thinking maybe I had a bad ribbon, but that doesn't seem...
run forgo diagnostic utility given on your installation cd
Try by doing all the tools under mechanics tab most importantly ribbon sensor calibration and advance & reverse ribbon drive motor by removing the ribbon as instructed by the manufacturer
Jan 06, 2010 | Fargo Persona C30 Thermal Card Printer
Getting this error code on 8550 Phaser: 37,006,42:26076 Have been having problems with the fan
Hi outonalimbwi:
Here is your problem.
37,006.42: PEST - Drum disconnect. The drum heater is not drawing the expected power from the supply.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Run the appropriate diagnostic test:
37,002.47 = Left Jetstack Heater
37,003.48
= Right Jetstack Heater
37,004.40
, 37,005.41 = Reservoir Heaters
37,006.42
= Drum Heater
37,008.44
= Preheat Heater
37,009.45
= (8500/8550) All ink melters
= (8400) Ink Melt 1
37,010.46
= (8500/8550) Ink Melt 1
= (8400) Ink Melt 2
37,011.47
= (8500/8550)Ink Melt 2
= (8400) Ink Melt 3
37,012.48
= (8500/8550)Ink Melt 3
= (8400) Ink Melt 4
37,013.48
= (8500/8550)Ink Melt 4
2.
Did the test pass?
Go to Step 3. Go to Step 2.
2 1. Check the wiring running from the component to the printhead.
2. Is the wiring damaged or not working properly?
Replace the wiring harness.
Replace in the following order:
■ Drum assembly
■ Preheater
■ Printhead
■ Ink loader
Aug 11, 2009 | Xerox Phaser 8500N Printer
Fargo 4250 card printer runs, but doesn't print.
take the ribbon out, and rewind it a little bit and see if you see print on it. if you dont, chances are your printhead is either bad or has loose cables going into it.
if you do see print, either your card is not aligning properly or the head lift motor might not be working (when the unit on, open the door, and press both buttons at the same time and see if the printhead does an up and down motion), platen roller is bad
May 12, 2009 | Fargo 4250 Thermal Printer
New ctg. change problems
In the printing preferences there is an auto detect ribbon button . you should select it.
Your ribbon will be updated. Also if printer asks you if the ribbon is correct select yes. The printer will then print on whatever ribbon you have intalled. This doesnt work with test prints
Dec 26, 2007 | Fargo Persona C30 Thermal Card Printer
Breaking since I change printhead
Hi, i think you must to adjust tension of ribbon.Go to menu and find adjustmento for tension,and try to adjust to "-" or "+" value, in small increaments.Print card and if no results,try again.
BR
Dec 05, 2007 | Fargo DTC525 ID Card Printer
Fargo DTC515 Thermal Printer Logo
32 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
pkwc
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
