Question about Samsung RS2534 Side by Side Refrigerator
What temp.should the ref. and freezer be - Samsung RS2534 Side by Side Refrigerator
  • 161 Answers
It says the setting on the inside of the fridge. Just turn the dial.
Posted on Sep 29, 2009
  • 44 Answers
Referigerator appx 36 degrees freezer -5 to -10
Bottom freezer not working freezer temp flashing at 6
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 23, 2011 | Samsung RB2155SH Bottom Freezer...
My Maytag MFI2568AES is giving problems with temprature setting. The temp light is flashing, the freezer is now at 59 and refregerator at 55, when I change the desired temp seetings, the referigerator does...
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 08, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Samsung ref model RB2044SL freezer works fine refridgerator side has no light and no temp cooling like the refridgerator side lost all power beeping constantly power freeze and everything on freezer side...
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 06, 2011 | Samsung Refrigerators
Ice builds up on the back wall of refridgerator
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 03, 2011 | Sub-Zero 650 / O Bottom Freezer...
Temp control not lit. beeps when pushed,but no temp read out. temp. worm in frig and freezer. compressor o.k.
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Aug 24, 2011 | Refrigerators
HIGH FREEZER TEMPS REFRIGERATOR TEMP VARIES FREEZER FREEZES UP
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Aug 24, 2011 | Samsung RB2155SH Bottom Freezer...
How do u reset ref bosch ref, not cooling cond fan was running slow and evap fan not working replaced condencer fan
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Aug 21, 2011 | Bosch Classixx KGV28323 Bottom Freezer...
I have a KitchenAid refr. mod. KSRL25FRSS00 it is turned down to the lowest setting and still freezes things in vegetable box. (new control board?)
Is your milk or eggs freezing? All the cooling in the refrig and freezer spaces is done in the freezer. Sometimes, the control labeled freezer temp controls a vent between the freezer and ref space, allowing air into the ref side. the other control determines run time. try turning thefrz setting up to raise the ref temp.
Nov 15, 2010 | KitchenAid Refrigerators
Will freezer work in low ambient temperature (i.e. 26'F)? I have a GE refrigerator/freezer (c. 1983) in a cabin which gets winter temps around 25 degrees. I found the freezer contents had melted and then...
The compressors are rated for ambient temp. and most refrigerator compressors are rated for abour 50 degrees F
to answere your question yes the ambient temp is a problem.
And as for the Thawing, the refrigerator will go into defrost every 8 to 10 hrs and turn on the heater inside the freezer for about 30 min.
You can also cause damage to the seal system and the compressor because the oil will become slugish inside the compressor.
In other resarch I found that because of the ambient temp the freon gas (mostly the newer freon's) won't work corectly because they stay in liqued form.
Jan 11, 2010 | Refrigerators
Placing a refrigerator in the garage
IF YOUR GARAGE TEMP GOES BELOW 35 THE REF MAY NOT WORK WELL BECAUSE MOST REF HAVE THE THERMOSTAT AS THE REF CONTROL. THE TEMP IN THE BOX IS SENSED AT THAT POINT AND SHUTS OFF, THE REF SEEM TO WORK BUT THE FREEZER WILL WARM UP.
IF YOU WANT TO USE A REF IN THE GARAGE, FIND ONE THAT HAS THE THERMOSTAT CONTROL AS THE FREZER CONTROL. LOOK AT THE CONTROLS, THE ONE THAT HAS AN OFF POSITION IS THE CONTROL THAT IS THE THERMOSTAT. SO, THE FREZER CONTROL SHOULD SAY "OFF" SOME NEWER REF WITH FULL ELECTROINIC CONTROLS MAY WORK AS THEY HAVE INDIVIDUAL SENSORS FOR BOTH THE REF AND FREEZER SECTIONS.
Jul 14, 2008 | Whirlpool EL7ATRR Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
207 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
