Question about Craftsman 24 Hp 48" Deck Yard Tractor
Deck raise/lower lever won't catch - Craftsman 24 Hp 48" Deck Yard Tractor
  • Chuck
    Chuck May 11, 2010
    Can you better explain "won't catch" also post your model and serial number
  • 472 Answers
YOU WILL NEED TO BRING THAT IN TO A SHOP TO HAVE THAT FIXED
Posted on Sep 30, 2009
How to lower the blade please
Pauline, most mowers have a lever on each wheel that sits in a grove. if you push these levers to the mower side you should be able to raise or lower that wheel. get all of them the same height. there are 4 of these. if it don't have these levers then there is a bolt that holds each wheel on if you take the bolt off you can put it in another hole to raise or lower your deck. good luck
Apr 20, 2016 | Garden
How to fix mower deck that will not raise or lower
only you or someone there can look under it and see what has happened . I would suspect some pin came loose and fell out .
Sep 24, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
Why can't I raise or lower the deck?
Sounds like you have jammed linkages which raise and lower deck, you can try this which usually works best with assistant.
With engine off, shake the deck vigorously (up,down, back and forth) while try to raise deck with lever.
Check for worn or damaged arms, springs, deck mounting points, etc and repair or replace.
Sep 01, 2014 | Garden
Mtd manual
MTD uses several different configurations. Electric PTO's are tensioned all the time by an idler pulley on a spring loaded bracket. Manual PTO's with an engagement lever have a movable bracket attached to the lever via a cable that will tension the belt when the lever is engaged. Another configuration is the deck engages when the deck is lowered with the deck height lever and disengaged when the deck is raised. In this case the belt is tensioned by a large spring from the rear deck support bracket to a mount on the transaxle and tension is released by a rod that pull the deck forward when it is raised.
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My JDL120 MOWER DECK WON'T RAISE OFF THE GROUND MORE THAN 1.5".iHAVE HIT ROOTS AND ROCKS OVER THE YEARS AND WAS STILL ABLE TO RAISE DECK NORMALLY.
First thing is to get down and look at the linkages. You may have a weld that came loose, or a nut that worked it's way off. You may also have something that bent.
Does the lever move all the way up but the deck doesn't move with it, or does the lever stick at the low level.
If it's sticking, you may just have picked up an obstruction like a stick or stone in the wrong place. You may also have a bent or damaged linkage.
Does one side or just the front or back lift up? One of the pins that hold the bars that it pivots on may have come off or broken as well. Looking underneath while someone works the lever for you can tell you a lot.
Sep 21, 2012 | Garden
2000 craftman lawn tractor 917.270822 blades will not engage
If your blades won't engage when you raise the lever to engage them AND that lever moves freely without the normally expected resistance, then you've lost the cotter pin that connects the lever rod to the mower deck assembly. Very easy fix! Using the mower deck raise/lower lever, lower the mower deck to "down" position. Now, lay on your side along the right side of the mower and look up (use a flashlight) under the mower at the top of the mower deck while moving the blade engagement lever "up" (which pushes the connected rod down). At the end of the rod, you will see a hole where the mower deck and rod connect. Align the hole at the end of the rod with the matching "pin" on the mower deck (you'll see it) and insert a new cotter pin to secure them together. Use a nail if you don't have a cotter pin. Voila! you are done. The blade engagement lever will now engage/disengage your mower blades successfully. Just remember that mower deck must be down, or lowered, before you engage the blades!
Jun 22, 2012 | Garden
My deck is way too low. How do I adjust it?
Your mower should have a lever on it that you move to raise or lower your deck. The lever will normally have the slots that it locks into numbered like the trans gears if yours is not automatic.
Nov 06, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
How to adjust mower deck height
There should be two threaded rods with a nut on them that goes from the frame to the deck. Check the height of each blade and which ever side is out of balance you can disconnect that sides rod (usually held onto the mount with a clip or cotter pin) and turn the rod to either raise or lower your deck until it is level.
The above was for leveling your deck.
If you just need to raise or lower the deck depends on if you have a lever on the right side with a push button on top just depress the push button and push forward to lower or pull back to raise.
It might have a round knob that you turn to raise or lower.
Good luck
Sep 03, 2009 | Garden
Craftsman 24 Hp 48" Deck Yard Tractor Logo
51 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
