Question about Panasonic Flat Panel Televisions
2001 32" tv flat screen
Won't turn on
SOURCE: protron flat 32' tv with broke screen need to replace
i have the parts
Posted on May 21, 2008
  • 30 Answers
SOURCE: LG LCD Flat screen 32 screen blank red light blinking cable on
Bad caps in the power supply. Replace all bad cap or replace Power Supply Module. If you choose to try and fix it yourself yourself will need a ESR Meter to check the caps in circuit. Let me know if this helps.
Posted on Oct 16, 2008
  • 1077 Answers
SOURCE: Can't see the top or bottom of screen on my emerson 32" Flat Scre
If it's like mine, there should be a screen mode button on your remote. Keep pressing it to change to different settings.
Posted on Feb 07, 2009
  • 2992 Answers
SOURCE: element 32" flat screen tv has cracked screen
Sorry to say, when the display is broken you're best off looking for a replacement TV.
There isn't any way to repair a cracked display except to replace it. You can try a Google search or check websites like that sell parts removed from junked sets. It's almost impossible to find replacement displays (unless you are a warranty servicer and get them right from the manufacturer) since most TV's are junked because of broken displays. And if you do find a display, there are still potential problems. Besides the cost (the display is the most expensive part, most of the set's cost), you need to be sure the display is exactly the same part as the one you're replacing. The same model of TV can use different displays depending on when and where it was made, and there may be differences in other parts in the set as well.
Posted on May 27, 2009
SOURCE: New 32 in flat screen Vizio tv will not turn on no
I had the same tv, same problem. take the back cover off and look for the 250v ceramic fuse (looks like a glass tube type, but is porcelin) For ease of replacement and a cost of about $00.80. I would start there. If that does not take care of it, than you can move on to the other options.
Posted on Jun 25, 2009
SOURCE: my rca 32" flat panel tv model l32wd22 won"t turn on
This worked for me also. I bent the prongs further apart to achieve a tight connection with the power supply cord (as you are looking at the TV the power cord is on the rear right side and disconnects at the TV; bend the prongs on the TV and simply place the power cord back on) Thanks, saved me about $330 on a new TV!
Posted on Jul 02, 2010
0 characters
1 Points
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Flat Panel Televisions
My 22 inch Vizio flat screen TV won' turn on with
short of taking to a shop for an estimate most of these smaller screens get replaced versus repaired.
Aug 31, 2012 | Flat Panel Televisions
Panasonic tc-p60gt30 won't turn on. Something hit screen. Screen did not crack but now won't turn on
May have damaged the PDP (plasma display panel) inside---if the panel which is fragile shorted inside it will trigger shutdown.
Aug 28, 2012 | Panasonic 60 TCP60GT30 3D Plasma TV
Westinghouse tv won`t turn on. blue light is lit
westinghouse flat screen light on lower part...can not get to stay on tv and no sound...what button so i push to go back to tv
Feb 26, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Flat Panel Televisions Logo
27 people viewed this question
Top Panasonic Flat Panel Televisions Experts
charlie rodriguez
charlie rodriguez
Are you a Panasonic Flat Panel Television Expert? Answer questions, earn points and help others
