Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The light in my Craftsman garage door opener does not work. I have replaced the bulb and it still will not go on.
    President:
  • 3,197 Answers
Unplug the opener and using a small screwdriver pull out on the center contact of the light socket.
Posted on Sep 29, 2009
    Sergeant:
    Champion:
  • 269 Answers
Check to see if there is voltage at the bulb receptacle using a volt meter
What part do I need to replace to get the lights to work on a Craftsman garage door opener?
Sounds like a broken or disconnect wire. At least start their. Unplug operator. Take the cover/shroud off, using a bright flash light check all the wires for breaks or disconnects. Repair or reconnect. Also check the bulb screw housing are connect on the back side.
Oct 03, 2014 | Craftsman 1/2 HP CHain Drive Garage Door...
After a lightening storm the light on my Craftsman garage door opener work. I changed the bulb but that's not the problem Thinking it may be the fuse, but where is it?
I'm guessing that some of the electronics got fried by a voltage surge.
If you can find your model number you can probably get a replacement board at sears parts direct,
http://www.searspartsdirect.com/
Aug 29, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
Light will not come on Craftsman 139.53615sr, changed light bulb still doesnt work
Unplug the opener and remove the light bulb. Take a small screwdriver and pry out on the center contact of the light socket. Replace the bulb and plug in the opener.
Dec 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
I am having a problem with my Craftsman 1/2 HP garage door opener 139-53910. My light bulb does not come on when the garage door is opened or closed as it should. I don't have a manual. Is there a...
Make sure the bulb is good. Unplug the opener and remove the bulb. Use a small screwdriver to pry out on the center contact in the light socket. Replace the bulb and plug in the opener.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
The lights on my liftmaster garage door opener suddenly stopped working I have already replaced the old light bulbs with ones I know work but the lights are still not working.
Unplug the opener and remove the light bulb. Using a small screwdriver lift up on the center contact of the socket. Replace the bulb and plug the opener in.
Oct 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Lights do not work on the garage door opener. what could be the problem?
Unplug the opener and remove the light bulb. Pull out on the center contact in the light socket. Replace the bulb and plug in the opener.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
My craftsman door opener light doesn't work I replaced the light bulb and still doesn't work tried pulling out the centre socket contact to no avail.
You have done all you can do if you are using a standard bulb. The light is controlled by a small relay on the logic board and that is probably bad.
May 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
1/2hp Craftsman Garage door opener light bulb
If you are getting a click the relay on the board sounds like it is working. Sometimes the contacts in the light socket gets burn spots on them. Try unplugging the unit, unscrewing the bulb and with a small scrapping tool (small flat screwdriver) scrap the bottom contact and the contact on the threads. Bend the contact on the threads a little too make better contact with the bulb. Screw the bulb the bulb in completely. If this does not solve your problem the only the left to do is to replace the logic board.
Jan 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener light bulbs burning out
You can replace the socket itself. Unless there is extreme vibration this will be your best bet. If there is vibration then use some rubber washers to lessen this. You can get replacement parts at chamberlain.com. Thanks BB
Mar 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
194 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
