Question about Whirlpool Calypso GVW9959K Top Load Washer
How do i get the front panel off a calypso(##@@!!!!!) washer?
That's easy, just remove the Calypso Logo on the front of the machine, then there is a screw you need to remove. Then slide the top forward, then lift it up. Have someone else hold it up, and remove 4 screws on the top of the front panel, then lift it up about an inch and remove away. Putting it back on, try to get the latches back on correctly on the lower right and left, or it will stick out and look funny.
Posted on Oct 01, 2009
Calypso front panel removal
Hi If you just need to get to the pump there is a access panel on the bottom.. flip it on its side and unscrew the panel you should be able to get to it... if you can't you can open the top with by pushing a putty knife in the front to push in the two clips and the top will hinge back.. then you can get to the screws to remove the front panel.. let me know how you do .. Thanks
Sep 08, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso washer smells how to get rid of ordor
Removes odor causing residue in front loading (HE) washers. Keeps your machine fresh and clean. Package includes 3 tablets. For front load washers only.
Here is what you need.
Oct 18, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
I have a whirlpool calyso washer that will not drain and is giving me the LD code. How do I check for blackages in the draining hose?
Pull the name tag off on front panel take screw off pull top forward and lift two more screws to take front panel off your pump will be on the right hand side close to the base of the washer
Jun 05, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Water leaking out of bottom front of washer
Instructions on how to get the front panel off for inspection starts on page 38 of this Tech Manual
Feb 04, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Water runs out underneath.
Pump is usually on bottom of machine towards the rear. Remove front panel or the back of machine. I think front is easier?
Jul 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
No power
You have this listed under a Calypso washer heading. The Calypso's don't have a latch mechanisim on the lid. To you have an Oasis or Cabrio? Those are top load washers by the some of same manufactures that do latch. If so, you would have to push the two green clips between the front panel and the top of the unit towards rthe back while lifting up on the top. You can get your clothes out that way if it is one of these models.
Jun 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
How to Open up a Kenmore Elite Calypso Wash Motion Washer
If this is a Calypso, there are retaining clips holding the top down in the front of the washer. You will need to look along the seam where the top meets the front panel the washer about 2 inches in from each side. Using a putty knife, insert into the seam and push straight in while lifting on the top. The retaining clips will release and the top lifts up. It may take a second set of hands to make this a little easier. When you get the top lifted up, there will be a couple of screws holding the front panel in place. Remove them and you have access to the interior of the washer. If this is not a Calypso, please post back so I can give you correct advice. I hope this helps you.
Apr 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Sears CAlypso
dont see why not, first t hing to do is find out where its leaking from, the fromt panel will need to come off to watch for leak in order to remove that , pop off the medalion on fron lip of the main top assy. ther should be a screw behind the emblem remove the screrw and the top will slide foward and then tio back. a few screws across the top of front panel will drop that panel down adn from ther you ll gain acces to watch unit work adn see where water is coming from
Apr 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso fl error
Look along the seam in the front of the washer where the top meets the front panel. About two inches in from each side is a retaining clip. If you take a putty knife and push in on the clip while lifting up on the top, the top of the washer should open up. You may need the assistance of another person and use two putty knives at the same time. It can be a bit tricky sometimes, but the top does open in this manner. Once you have the top open, carefully rest it against the wall behind the washer. There will be a screw holding the front panel on at each top corner. Once you remove the screws, the front panel should come off exposing all the internal components of the washer. You can also remove the back panel for additional access. I hope this helps you.
Whirlpool Calypso GVW9959K Top Load Washer Logo
506 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
