Question about Kenmore Dishwashers
Water wont drain out of dishwasher. yes I check the lines and pushed the drain button.
  • 44 Answers
Shut the power off at breaker, let sit for 30 minutes plug back in if it works then you may have lucked out and the main board just went stupid. If it doesnt work chances are the main board took a dump and must be replaced
Posted on Sep 29, 2009
Whilpool gu2300xt,wash cycle lights wont light,when i push start button goeswt calcell and drain and you can here drain pump then it shuts off
It is likely there is some fault with the float switch. Which means the dishwasher thinks it is overfilled with water and tries to empty out to protect itself. This is why the pump turns on as soon as you try to run the dishwasher. Refer diagram. You need to check if the float (12) spring is responding by pressing it down and checking if it comes up. Also level switch could be faulty.
Jan 12, 2013 | Whirlpool Gold 24" Tall Tub Built-In...
Dishwasher not draining
The problem is a clog in the hose or the check valve from the drain pump. I will post back shortly with directions to unclog it.
Thanks/Mike
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
My Kenmore Elite dishwasher did not drain the water out of the bottom after the dishes were washed last night. Could I possibly have pushed a wrong button to keep it from draining, or do I have a problem?...
Yes , If the program controller has hung it would have skipped the drain cycle. So try to redo the cycle and see if the drain works, is not check the program controller and the drain valve/pump.- if there is food particles that have clogged and blocked.
Jul 26, 2011 | Kenmore Dishwashers
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
When the cycle was done I had water standing in the bottom of the dishwasher. I checked the drain line and it is not clogged or crimped anywhere. I pushed the button to drain it out and it is still in the...
can you here the drain pump coming on there may be a small piece of glass or something in the pump not allowing to flow out of the dishwasher
Aug 25, 2010 | Dishwashers
WHICH BUTTONS DO I PRESS TO FORCE THE DISH DRAWER TO DRAIN EXCESS WATER?
Just run the shortest wash cycle and check if it empties in the end. If not, then you have some blockage in the filter sump.
Go to the part of the user guide which explains how to clean drain filter and filter plate.
Hope this solves the problem.
Jul 04, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
My dishwasher wont drain out? any ideas?
Start checking drain hose first.
Check water level switch.
If water level is ok check drain pump lines , and test drain pump.
If everything else is ok, test the control board (uncommon).
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 17, 2009 | Kenmore Dishwashers
My dishwasher doesnt drain and the drain button is flashing
ok if it doesnt drain properly... it means the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up.
check these: Drain line/air gap Pump Drain valve and/or solenoid Belt Motor Timer
Air gaps are installed in the drainage system to prevent the discharge from the dish washer to enter the sewer system and the contaminated water to drain back into the dishwasher after the pump stops.
When we install a dish washer we loop the discharge hose as high up under the cabinet as we can and secure it with pipe straps.
This creates a air gap so that when the pump stops nothing from the drainage system can flow back into the dish washer.
we ll now see how to check the pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm.Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller.
if u see any of these parts broken u wud need to replace themnow the next thing to check wud be the drain valveMany dishwashers use a drain valve with an electric solenoid.When electricity flows to the solenoid, the valve opens and diverts the water to the drain.Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly.To access the drain valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel.It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. Look for a water hose running from the motor or underside of the tub. The hose should lead to the drain valve. now we need to check the motor ... now u might not be required to come uptill this iam giving u instructions just incase
If the motor isn't turning or working, the unit won't drain If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week,you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors just can't be serviced.also refer the following links http://www.acmehowto.com/howto/appliance/dishwasher/check/airgap.php
http://www.acmehowto.com/howto/appliance/dishwasher/check/timermotor.php
regardsiversh
Apr 27, 2009 | Miele 24 in. G645SC Plus Free-standing...
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
Jun 13, 2007 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Dishwashers Logo
67 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
