Question about HP LaserJet P3005n Printer
Hi am george, my printer is printing fade documents and i have tested the cartridge on another printer but its OK ? what could be the problem
    President:
  • 2,306 Answers
Check inside above where the drum goes, there's a inch wide window that the laser shines thru to put the image on the drum. Sometimes it's coated with toner and needs wiping with a dry soft cloth. Otherwise the power supply for charging could be failing.
Posted on Sep 29, 2009
Yellow ink faded on one side of copy
Ink News - How To Correct Faded Prints From Toner ...
www.inkpal.com/ink.../tips-to-correct-faded-prints-from-toner-cartridges...
Rating: 3 - ‎12 votes
Mar 30, 2012 - You should particularly suspect this if the prints are faded on only one side and if the printer is not telling you to replace the toner cartridge.Missing: yellow
HP Officejet 6500 Printers - Fixing Print Quality Problems ...
support.hp.com/us-en/document/c01641184
Jan 16, 2016 | Office Equipment & Supplies
While printing or copying top part of print fades out in my canon 2018 n copier
A cleaning will solve the problem, follow these steps;
- Open the document you want to print - Go to file > Print - click properties in the print window - in the menu select 'Maintenance' - in the 'Maintenance' click 'Ink Cartridge Settings' - select Black Only - click OK - click OK - now you can print only using the black ink in the printer.
Hope this helps.
Please leave a comment and rate if this solution was helpful. thanks!
Jul 26, 2011 | Office Equipment & Supplies
Black print is faded on my HP deskjet 6980 printer. Whenever I print a word document it will have sporadic fading. It will be fine in one place then all faded in another. I've cleaned the cartridges and...
Here are some steps you can check to resolve your issue.
Check if the ink cartridges are low, specially the color black since if the black is empty, you are using the colored cartridges to print black. If the cartridges are newly replaced check the cartridges by reseating it. Try to consider changing the print quality high but doing so will use more ink. If still the same try to clean your printer heads.
Here are the instruction for cleaning your printer.
Open the printer tool box. (open a word, then click on file then print, choose properties, then services)
click on clean the print cartridges, then clean. Do test printing as well to check if the color is correct. If still the same calibrate the color which can be found in the same menu.
For more information here is the link for step by step instruction with visuals.
Hope this will help you resolve the problem.
Thank you for choosing fixya
Mar 03, 2011 | HP Deskjet 6980 InkJet Photo Printer
Printing won't work.
Good day sir/maam, hi, when you test print it usually prints letters and no lines are printed. try first if the printer is setup to economy/draft or pictures, if lines are faded, the ink cartridges maybe dirty. manual cleaning is needed, the ink path starts from the ink cartridge to the cradle or carrier then to paper. so any dried ink that blocks the path can affect the printout. you can use warm water to loosen dried ink. remove the cartridges and cradle from the printer as you clean them.
Oct 27, 2009 | Office Equipment & Supplies
HP 3200 Photsmart Printer will not print properly.
You can always perform the print nozzle cleaning procedure through your printer's software. If it is new, then the black cartridge has malfunctioned. Take it and your receipt to exchange it for another. I'll bet this is the problem since your color is working OK and your text is grayscale (partially working).
Jul 19, 2009 | HP PhotoSmart 1215 InkJet Printer
Faded or no printing of documents
First, have you removed the protective tape from the bottom of the printer cartridge? I know it sounds simple, but it's something easy to overlook when you install a new cartridge.
Jun 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Faded print job
ok...have you tried a clean and re calibrate lately on those print heads?
Mar 20, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Color fading
Hi , the printer are dried up need head cleaning twice then test print , if color of test print are complete color no spaces ,it means head are clean .
Jan 18, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Eadch line of text is slightly faded at the bottom from laserjet 1100
It is possible that the transfer roller needs replacing as this causes it. Have you recently wiped clean the black roller that sits under the toner cartridge if you have you may have damaged it.
Best thing is to replace the transfer roller very easy to do and not expensive.
Hope this works for you and please rate me
Thanks J
Oct 11, 2007 | HP LaserJet 1100 Printer
HP LaserJet P3005n Printer Logo
80 people viewed this question
Seeker5211
Seeker5211
