Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
KENMORE RANGE DOES NOT GET HOT - Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
    President:
  • 1,304 Answers
Open the oven
take out the trays
take out the bottom
close the door
'tun oven on bake set to 350
watch through the glass you should see a very very bright glow
in about a minute or so
if not its your ignitor
replace that and you should be fine
i would have included the part number but your missing part of the model number
go to www3.sears.com
Posted on Oct 06, 2009
I have a kenmore range # 79094152310. And when I turn on the right front burner, the top of the oven gets so hot you would get burnt if you touched it, is this normal for this stove?
no --not normal
stoves even glass top stoves are only hot in vicinity of the hot plates
if the whole top is hot , call an electrician in to check the systems
Oct 02, 2016 | Kenmore Kitchen Ranges
I have a kenmore ceramic top electric stove and one of the burners quit getting hot. what could be the problem
It is a kenmore glass top stove about18 years old. One of the burners stop working just wondering if I can fix it myself?
Aug 06, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
I had my Kenmore Range for about 7 years now All of a son the oven does not seem to get hot enough What do you think?
i would have the thermistate replaced its really all it can be unless your jets are half blocked but unlikly
Jun 19, 2010 | Kenmore 75912 / 75914 / 75919 Gas Kitchen...
I can't find my model number on my Sears Kenmore Gas stove. Several times now the stove has beeped then kicked out with EO and F2 showing in the clock area. The stove was bought in 2000 or 1999. Can you...
The tag with the model number is usually located on the rail that is visible with the lower drawer open.
The code you are getting is an indication that the oven got too hot or the control thinks the oven got too hot. It is usually do to one of two parts that have failed.
If the oven did not get too hot and you got the failure code, then the sensor would be bad.
If the oven did get too hot then the ERC (electronic range control) is bad.
May 17, 2010 | Kenmore 75012 / 75014 Gas Kitchen Range
I am getting a E2 F2 code on my kenmore electric range model 95014102, pressing the clear button does nothing, I unplugged the stove and the code went out for a few days it is back on. What could be the...
The E2 F2 is an indication that the oven got too hot and shut down. If the oven actually got too hot the issue is most likely the main control board. If the oven did not get too hot the problem would be the sensor.
May 08, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
The bottom element in my Kenmore oven just got red
Yes. Unplug the range, remove the screws, holding the element, remove element, disconnect wires on the ends of the element. Installation is the same in reverse. Complete model number is needed for the part# of the element
Mar 04, 2010 | Kenmore 96422 / 96424 / 96429 Electric...
Gas cooktop flames are too high
are you natural gas or lp
and is your range set correctly
is your flame blue
or orange
Sep 15, 2009 | Kenmore Kitchen Ranges
Hot surface light indicator stays lit
The hot surface light is controlled by a part attached to the element called a limiter. For your model, the limiter is not available as a seperate item. The element/limiter assembly has to be replaced as a single unit. The top assembly, elements and limiters are all fragile parts.
If you are making this repair yourself, make sure the range is disconnected from it's power source prior to service.
Apr 27, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
201 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
