Sharp projection tv lamp replacement
Model xv-z1u - replaced bulb but can't get projector to turn on.  can't find manual on-line to help.  the other sharp manuals refer to "resetting the lamp timer" code but that code did not reset mine.  Thanks, Mike
  • 108 Answers
Rear Projection Televisions are not like other televisions that can run maintenance-free for 20 years or more. They need to have their lamps changed on occasion, and most have air filters that need to be cleaned every month or two. Lamps typically last about 8,000 hours on most models high end models, some of the cheaper models last only 1,000-2,000 hours. Keep in mind however that some lamps won't make it all the way to their estimated life spans. If you operate your LCD or DLP TV in a warm environment that is not adequately ventilated, or at higher elevations, this can reduce lamp life. Failing to keep the air filter clean may reduce lamp life as well. And some lamps will just fail sooner than others--estimating average lamp life is not an exact science and testing methods vary greatly among manufacturers.
ere is a checklist of what to do to get the most out of your lamp:
  1. Check out the presets and select the setting with the lowest light output.
  2. Once you've done that adjust the brightness down to your liking. The lower the brightness the long the lamp will last.
  3. Check and clean the air filters on a monthly basis. Having a clean air filters means that your lamp has better airflow. Air is what is used to cool the lamp and the cooler your lamp runs the longer it will last.
Each owner's manual for a rear projection TV comes with instructions on how to replace the lamp. Here are the typical steps for replacing a lamp.
  1. Turn your TV off. Let it sit there for about 5 minutes to let the cooling fan help cool the lamp.
  2. Unplug your TV from the power let it sit about another 30 minutes. Even with the TV turned off power is still going to the lamp and the lamp receptacle can still be hot enough to burn you. Even if you think that the lamp is cool I recommend that you do not touch the receptacle.
  3. Usually the lamp has a cover that you will need to unscrew. Most manufactures use a Philips head screw for holding the cover shut. Unscrew the lamp cover.
  4. Unpackage the replacement lamp. Be careful not to tough the glass, as oil from your fingers can damage the lamp's surface.
  5. Pull the lamp out. Most lamps have a plastic tab or hoop on the handle that you can use to pull it out. Follow the owners manual for specific instructions on how to pull the lamp out. Make sure you do not touch the surrounding lamp housing if you just turned off the TV. It can burn you if it is hot.
  6. After the lamp has cooled, place it into the empty box of the replacement lamp. Never put the used lamp into a plastic bag.
  7. Using the guiding post also called "gutters" by some manufactures slide the lamp replacement lamp in pushing it until you hear a firm click.
  8. Screw the lamp cover back in.
Posted on Dec 23, 2007
Bulb popped after replacement
100% Original lamp for XV12000
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Sep 06, 2013 | Sharp BQC-XVZ100005 Projector Lamp for...
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
I have a sharp projector xv-z9000u. I replaced the lamp and now I cannot turn on the projector. What should I do?
there may be a reset button some were on the projector you have to look real good, i do know that some projectors when you replace the light bulb you have to push the reset button than it should turn on.
Jun 04, 2011 | SharpVision XV-Z9000U Multimedia Projector
How to reset the lamp usage for Sharpvision XV-Z1U
Press and hold VOL. DOWN and ADJ. DOWN (ARROW DOWN) while turning oh the main power switch.
Sep 22, 2009 | SharpVision XV-Z1U Multimedia Projector
I need to replace the bulb in my Sharp XV-S55U projector. The manual does not show how to change bulb. I can find the part on the internet but not the "how to".
Hi There If you want we are able to supply lamps as we ship internationally and also the same with our ICE Digital Daytime projection screens. This lamp however is now getting difficult to source so you might want to consider selling it whilst at least it is working. Regards Kevin Andreassend ICE AV Technology Ltd +64-9-414 2348
Apr 08, 2009 | SharpVision XV-S55U Multimedia Projector
Sharp xv-z1u
Hi Scott
Just a quick question - Does the LED's on the top cover light up when you insert the power cable ?
Apr 22, 2008 | Sharp XR-1S Multimedia Projector
Lamp life over 2000. can't turn on again after replaced
sharp xv z9000u bulb reset
Hold down Enter + down arrow + right arrow and then power on.
Mar 13, 2008 | SharpVision XV-Z9000U Multimedia Projector
Light problem
Hello Nick,
There is a way to reset your projector. Hold down volume down button along with adjustment down button then power up projector with main switch.
Dec 05, 2007 | SharpVision XV-Z1U Multimedia Projector
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
