Question about Toshiba Satellite M30 Notebook
My laptop's screen is messing up
My laptop's screen is only visible when I tilt it really far back and will sometimes black out on me for no reason.
  • 68 Answers
This happens when the backlight cable is lose
laptop sceen is an LCD which uses a ccfl backlight to light the screen
this backlight wire sometimes gets lose as it passes through the laptop hinges
get a proper technician to tighten the wire to to put a new one
Posted on Sep 29, 2009
Compaq laptop green pink screen pixalted
One of the things is to hook it to another monitor and see if that still happens. If it does not then it is most likely the screen on the laptop. Not to worry though it could be the cable that connects the laptop motherboard to the screen. When you open and close the lid, it flexes the cable and the little wires in can break. The cable is not cheap though. One way to test this is to change how far the lid opens by flexing it open and closed to see if the screen changes. If it does then it is that cable.
Jan 19, 2014 | Compaq Computers & Internet
No display at power up
Lean the display as far back as you can and see if you can see the start up screen "shadowed" across the screen. If you can then the backlight burned out and you need to replace it. Sometimes a reall bright flashlight will help you see whatever's on the screen if the light burned out. Just hold the light up as close as reasonably possible to the screen and the icons and stuff should be visible.
Another thing you can try is toggling the onboard/external video by pressing F4.
Nov 06, 2013 | Toshiba Computers & Internet
When I move the lid of my laptop the screen messes up
it seems the wire that used to connect between display circuit and motherboard connector has got problem. So please check each wire and also reconnect the connector which connect to the motherboard of your laptop.
Apr 01, 2013 | Compaq Presario Cq-62 15.6 Laptop Lcd Led...
Black line down right side of screen
turn off laptop.
press and hold on the D then press Power button.
during the LCD BIST test check if the black line down right side of the screen is visible. if yes LCD needs to be replaced. if not connect your laptop to an external monitor check if the black line display appears to the ext monitor, if yes uninstall / reinstall video driver if fails replace video card or if it is built in replace motherboard.
if no ext monitor available then run PSA (press and hold Fn key then press Power button)
check if the black line is visible. Check also in BIOS is black line is visible, if yes then uninstall reinstall first the video driver if fails replace LCD.
Oct 11, 2009 | Dell Inspiron 9200 Notebook
Connect broken laptop screen to external monitor
Suggestion- on my toshiba fn-f5 switches display modes, but to remove display connectors, you may have messed up your keyboard ribbon cable connection. it probably has a small sliding lock to hold it in place- if the lock isn't tight, your keyboard may not be recognized, which could mess up your display. Also, make sure your battery is charged and/or your power supply to your laptop is connected. hope this helps!
mothmanmeg@gmail.com
Sep 06, 2009 | HP Pavilion dv6000z Notebook
Laptop screen goes black
its a lose connection from your inverter. i fix this how many times. this is a common problem.
Jul 10, 2009 | E-Machines M5310 Notebook
Black screen mouse pointer visible after i enter my password
hi..this problem is due to the loading drivers
during the time of login.The reason for the problem
may be due to the following reason.some files could
have got corrupted while loading drivers that may be
some damage due to the windows file corruption or
due to the virus corruption.
try it out..
thank u..
Feb 05, 2009 | HP Pavilion dv4000 Notebook
Sony KV27FS120 Tilt correction
Use the tilt adjustment in the menu system or if that doesn't go far enough, move the metallic object, (loudspeaker etc) further away from the screen.
Jul 26, 2017 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Blackberry lcd screen replacement instructions
This sounds like you have a broken lcd screen. If you feel comfortable with replacing the screen you can purchase a new screen off ebay.
If you are not comfortable I would recommend cellulardr.com they sound pretty reasonable as far as price goes.
I hope this helps
Please rate my answer..
Aug 16, 2008 | Cell Phones
Sanyo Projector==No signal
Hi, Perhaps you can try lowering the screen resolution first of the laptop before plugging in the projector and then the Fn + F8. Thereafter, gradually increase the screen resolution until projector stops displaying. The idea is that your current screen resolution maybe too much for the projector to handle. This of course is assuming that there is no hardware problem with the projector. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 10, 2007 | NEC MultiSync GT1150 Multimedia Projector
Toshiba Satellite M30 Notebook Logo
157 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
