Question about HP PhotoSmart C4480 All-in-One Printer InkJet
One line prints blurry, next line is fine, next line blurry,
I have a new C4480 - when it prints one line is blurred and the next line is fine, then the next line is blurred and then next fine again. I have deleted the software and reloaded it twice but no help. I have loaded onto 3 different computers but same results. I have run the alignment prcedure, the print head cleaning procedure, etc just as instructed but still no help.
  • 51 Answers
SOURCE: blurred printing
You should be able to re align the printheads using the software package on the computer which you installed whenn you installed the printer
Posted on Jul 23, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
  • 27 Answers
SOURCE: Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Posted on Mar 05, 2009
nassimjd
  • 104 Answers
SOURCE: How can I clean my printer heads on my HP Officejet 4580?
that utility is in the properties of the proper printer.
Posted on Mar 26, 2009
SOURCE: Will not print black , HP PSC 1610 All-in-One
Here was the solution. You MUST use HP brand black cartridge. Originally I purchased a #94 Office Max brand black cartridge. After it did not work I took it back and they gave me a second Office Max brand and that did not work either. So I took it back and they sold me an HP brand (I only needed to pay the difference in price so Office Max was good to work with). I installed the HP #94 black cartridge and everything now works.
Posted on May 11, 2009
The printing is blurry. How can I fix it?
I would start by cleaning under the print head. You could have some dust that's causing the blurring.
You can also run a "cleaning cycle" and a "head alignment" which may help.
Mar 01, 2016 | Canon Pixma MX410 All-In-One Printer
Epson workforce 600 blurry 5th line
Update: Blurring of every 5th line occurs in text mode but not text & image mode. Know of a way to see text & image as default for all print jobs?
Aug 18, 2012 | Epson WorkForce 600 All-In-One InkJet...
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
First two letters on the left are blurry. The
Look inside behind where the carriage is, the plastic strip behind the carriage probably has an ink or grease spot right where you see the blurred letters. Wipe that strip carefully with a Q-tip moist with alcohol, and the blurs should go away...
Dec 13, 2009 | HP PSC 1210 All-In-One InkJet Printer
The Color is printing blurred?
Could be down to dirt contamination in the laser scanner
Oct 10, 2009 | HP Color LaserJet 2600n Printer
Printing every few lines blurry, but not every line.
Printer head is clogged, be sure to clean it until you get the solid lines
Jul 11, 2009 | Epson Stylus R380 InkJet Photo Printer
HP Photosmart c4480 - poor quality photo prints
you shoud test printhead,if they are ok, you choose "best photo" in printer property.
Jun 26, 2009 | HP Photosmart C4480 All-In-One InkJet...
Double Blurry Print
Usually hairs sticking to the underside of the print head causes this.
I gave a solution to an Epson CX6400 user who needed to physically clean his print head. Look this up in the solutions. It involves using folded kitchen roll under the print head with the printer switched off and the head unlocked and free floating.
It would take me ages to type this again so please look this up.
The user had jammed paper and cleared the jam but had paper stuch to the underside of his print head.
I hope this helps.
Nigel
The INK Store
http://www.the-inkstore.co.uk
Jan 17, 2009 | HP PSC 1210 All-In-One InkJet Printer
Brother MFC-210c prints some lines blurred, letters stacked - alignment ok.
i have the same problem. repeated cleanings seem to help, when i print large fonts they come out pretty clear, but the smaller the font, the worse the blurring. 600 DPI prints mismatching patterns, but 1200 DPI prints perfectly fine. so i have found that printing on "fine" quality instead of "fast" or "normal" quality improves print quality ALOT. it uses more ink, but i am in business and need to be able to read very fine print!
May 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
48 people viewed this question
Seeker5211
Seeker5211
