Question about Ryobi Garden
Ryobi rht266oda 26cc petrol hedge trimmer. runs well blades move but will not cut very well, only got last year and went well, nut and boult came loose this year first time out was mended but will not cut, engine sounds ok
  • 437 Answers
You may need to take it to a professional to sharpen. It may have some trash in between the blades keeping it from not cutting. Plus when you use it try spraying some WD40 on the blades to help them move and cut.
Posted on Sep 29, 2009
I have a petrol hedge trimmer TRY26PHTA. The engine will start fine but the blades will not move
If the engine starts 'fine" then it has not seized.
Many, if not most, hedge trimmers are , for safety, equipped with a "CENTRIFUGAL CLUTCH" between the engine and the blade to prevent blade operation unless the engine is at full RPM.
IF your machine is so equipped, it's possible that the clutch is worn and slipping so badly that the blade can't move.
Jun 11, 2014 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I Have a 26 cc ryobi hedge trimmer. I cannot find any where to oil the thing. I've just been oiling the blades. I know its a 2 cycle but shouldn't there be some where to oil the blades other than dir
check to see if there is any holes in top or bottom of bar to grease or oil, if not there should be screws on bar to remove cover to gain access to blades, also on bottom of engine there is a cover useully with 2-3 screws holding it in. remove cover to grease gear mechanism, do not remove gears inside.
Dec 01, 2011 | Ryobi Factory-Reconditioned 26cc 22" Gas...
Electric hedge cutter,blaDES STICKING,hit them and they go again,plenty of power in the motor but blades sticking getting worse all the time
Could I suggest maybe using some dry lube on the blade surfaces, such as graphite or anti-seize compound? It can only help. I also recommend maybe a close inspection of them to identify the bind point and why they are binding at that point.
Aug 13, 2011 | Ryobi Factory-Reconditioned 26cc 22" Gas...
My hedger turns off when I turn it side-ways to
The problem with Ryobi trimmers is the siting of the fuel outlet pipe the trimmes has to be full of fuel at all times
Jul 11, 2010 | Ryobi 26CC, 22 In. Hedge Trimmer
Homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
Cutting blade doesn't move
a homelite is disposable, get a new one. You can pull it apart and see what broke and how much the new parts are. worst case, get the new one.
Apr 26, 2009 | Homelite Factory Reconditioned 26cc...
What is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
If it is a 2 stroke engine, a 50:1 ratio should work. That's 50 parts gas to 1 part oil.
Dec 10, 2008 | Ryobi 26CC, 22 In. Hedge Trimmer
Add on hedge trimmer ryobi weed eater
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Sep 14, 2008 | Ryobi 26CC, 22 In. Hedge Trimmer
Trimmer weight problem
blade size will determine the hedge trimmer's weight. Make sure it feels comfortable as you will be holding it for long periods of time at awkward angles.
Aug 27, 2008 | Ryobi 26CC, 22 In. Hedge Trimmer
Garden Logo
562 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
