Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jennair Oven doesn't heat
I have a double Jennair oven that does not heat up. I get an f5 error message from the upper oven and an fr message from the lower oven. Any suggestions?
  • 26 Answers
Have you reset the power off for 5 minutes and it returns
Posted on Jan 09, 2008
Rbd305pdb14,have error ( F5-E1) replaced controlled board, replaced touchpad, replaced sister board, replaced thermal fuse lower oven, replaced lower oven heat sensor, top oven works ok, lower oven still...
that's a bad door latch,if you use the self clean don't use it anymore,the oven gets up to 1000 degrees and damages the electronics in the oven,takes out the clock assy. the door latch things like that.part number WPW10195934 go here to see parts go here put model number in and look up parts,also you can check all the error codes down in bottom right hand side
https://www.searspartsdirect.com/model-number/RBD305PDB14/1198/0125300.html?searchType=modelSearch&q=Rbd305pdb14&searchTerm=Rbd305pdb14
go to upper oven and look at part number 22,you should have googled the error code before you changed out all those parts.
Feb 06, 2018 | GE JTP48SFSS Electric Double Oven
Kitchen Aid Superba double oven
f5e1 is a door locking error. try shutting off power for a minimum of 2 minutes to reset the control board. If you still get the error replace the latch. Here is the part to order.
Jun 19, 2013 | KitchenAid Architect Series KEMC308KSS...
F5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Nov 28, 2011 | Thermador SC302T Electric Double Oven
I have a GE JTP27 double oven, now 12+ years old. For last 2-3years, having consistent problem with upper oven where, after oven heats up and/or starts baking, we suddenly get a beeping sound and an error...
Greetings,
its possible to be the oven sensor or something in the lock circuit...if all else fails then in the electronic oven control which costs 125.00 or there about...might find cheaper price on ebay or internet search The sensor about 40-60 dollars, but without a complete number its hard to be exact with a price or part list...if this is helpful ..please let us know or if I can be of more assistence. let me know...Bruce Denton
Dec 28, 2010 | GE JTP27 Electric Double Oven
E1 F5 Error on Whirlpool Accubake Oven
The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Apr 07, 2009 | Ovens
E1 and f5 error/Door locked
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Dec 22, 2007 | KitchenAid KEBC207 Electric Double Oven
Jennair range
f-5 means the clock/oven control is bad. the only way to fix this is to replace the oven control
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
GE Double Oven JKP45BA, lower oven wont heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 30, 2007 | GE JTP48 Electric Double Oven
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
388 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
