Vibration problem with Frigidaire front load washer.
Frigidaire front load washer model FWT 445GES1, built 01/97. Worked normally until began vibrating badly. Removing lower front cover shows left side shock absorber has broken. Is this a user replaceable part? How far does the unit need to be disassembled to replace? Any special tools required? Former auto mechanic so have some experience using tools. Prior to vibration starting, unit was in good working order.
Thx 4 the help.
    Scholar:
    New Friend:
  • 67 Answers
Can't tell you about your particular model, just some generalities:
Unless the shock actually failed from a defect, you might have broken or damaged something else. Check especially for wires or other parts pinched between the tub and other parts or the housing. Also, make sure the tub shaft hasn't broken or worn the seal at the rear or the seal at the front. If this unit has ballasts one of them may have broken or broken loose to cause the shock to break. I had one similar with that problem. Might want to take the ballasts off the tub or brace it to keep from stressing the bearing and seals. Mine had three ballasts, one large cast iron one on top of the tub and two concrete ones either side. One of the concrete ballasts broke and the tub vibrated and pinched wires and damaged seals and was totaled. If nothing but the shock is broke, it's probably worth repairing. However, the other shocks also have the same amount of wear, check them carefully first. Also, check the seals while you're in there. Use a digital camera and take pictures of everything before you take it apart and be very careful with wire routing. Most parts are held with (probably) metric and Phillips. Always unplug it to work on it and plug it into a ground-fault protected circuit. Best to set the machine up to run then plug it in remotely if possible.
Posted on Dec 19, 2007
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Frigidaire Affinity Front-loading washer wont do anything
Check the wall socket with another electric gadget. Check your washer plug fuse. Finally open up the rear (after taking the washer power cord off the wall of course!) and disconnect and reconnect all wires and connectors one by one. Possible it could just be a loose connection somewhere. Sometimes happens due to vibration.
Click so pl if helped.
Apr 05, 2013 | Frigidaire ATF6000ES Front Load Washer
Having bad vibration issues on spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 18, 2011 | Frigidaire Affinity ATF7000E Front Load...
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Water loads after cycle is complete even with door open!
Dear Katie
ngfam at you service,
Sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Aug 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Loud noise during spin cycle
I bought the frigidaire affinity washer. It was quiet until it began the spin cycle, then it sounded like a jet taking off and began to bounce. Come to find out we set it up improperly. You must remove all shipping bolts on the back of the machine and make sure it is level. Ta Da!! it now runs perfectly quiet with little vibration.
May 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Same as many - Washer does not spin or agitate but everything else works fine
your brushes are gone you will have to wright down you model number and look on ebay there really cheap
Jan 07, 2008 | Frigidaire ATF6000ES Front Load Washer
LOC ERR
The control panel may in *LOCKED* mode. Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel. Make sure the detergent tray is fully closed too.
Feb 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
476 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
