Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice inside freezer - GE (PSS26MSRSS) Side by Side Refrigerator
  • GE Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorice inside freezer - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 28, 2010
My refrigerator stopped making ice and pouring water.I wanted to open the draw to the ice maker to see if there is chunks of ice inside but, it seems to be stuck it will not budge. Any suggestions?
put all your frozen stud in a cooler with a bag of ice then open your freezer door wide and lay a hair dryer inside and turn it on ....put a towel inside yto soak all the melted ice and be sure not to let the hair dryer get wet...put it on a shelf in the freezer and let it run till the freezer is warm and dry they your freezer will work again
Oct 04, 2016 | Samsung RFG298HDRS 28.5 cu. ft. French...
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
Ice buildup from water feeding the ice maker
Are you certain that the ice build-up is actually originating from the water flow into the icemaker? If ice is built-up on the rear freezer panel, then your problem is more than likely a defrost component issue (defrost thermostat or defrost heater(s). If the ice is built-up on the side wall of the freezer near the icemaker, then water is probably being diverted inside the water inlet tubing that goes into the icemaker. This diversion is usually caused by an accumulation of ice inside the water inlet tubing. You will probably need to remove the icemaker in order to glance inside the water inlet tubing to see if ice is in fact inside the tubing. If so, take a screw driver or other object that won't puncture the tubing and remove the ice.
Contact an appliance service company if the ice is on the rear freezer panel.
Feb 17, 2010 | GE GSH25JFR Side by Side Refrigerator
Water is leaking from top part of freezer down to bottom of inside of the frig. Frost is on the top of the frig in the frigerator.
FIRST STEP: UNPLUG THE REFRIGERATOR. AFTER IT'S UNPLUGGED, DO THE FOLLOWING:
Remove the food from the freezer compartment and place inside the refrigerator temporarily.
Remove the bottom panel and back panel from inside the freezer compartment. You will probably notice that the bottom of the inside of the freezer is covered in ice. Use hot water (not boiling) from the tap and pour it on to the ice that is formed on the inside of the freezer compartment to melt the ice.
CAUTION: DO NOT USE A HEAT GUN TO MELT THE ICE AS IT WILL MELT THE INSIDE OF THE FREEZER COMPARTMENT. ALSO DO NOT CHOP AT THE ICE WITH A SHARP INSTRUMENT OF ANY KIND AS THIS WILL PUNCTURE AND DESTROY THE INSIDE OF THE FREEZER.
If you have a wet vac, you can remove the melted water using the wet vac. Or you can use a towel to mop up the excess water. You will still have to pour hot water onto the ice until all of the ice in the freezer is melted. Patience is key as it takes time to defrost all of this ice.
You will see a drain hole in the back of the freezer compartment that is still clogged with ice. You will need to continue to apply hot water until the ice has completely melted.
Note: When the ice in the drain breaks free, you will see all of the water disappear as it empties out.
In Whirlpool refrigerators, the water runs to a tray underneath the refrigerator. You will hear the water empty out into that tray. Then you will know that you have completely cleared the ice from the drain pipe in the freezer. To double-check this, take a small cup of warm water and dump it into the drain hole and you will see it visibly disappear and run into that tray underneath the refrigerator.
Replace the freezer panels back into the freezer compartment and plug it back in and return your freezer items back in to the freezer and you should be all set.
Oct 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Coils inside freezer keep icing up.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model of fridge)
Aug 08, 2009 | Refrigerators
Ice in freezer compartment
Check to see if your drain tube is clear. Sometimes it freezes up at the base of the rear cover in these bottom freezers. Causing an ice dam.
Jun 30, 2008 | LG LFD22860 Stainless Steel Bottom Freezer...
Layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
Jan 20, 2008 | Freezers
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
