Question about Mitsubishi VS-50501 50" Rear Projection Television
No picture Was working fine, now no picture at all, totally black screen. Audio words fine. Pulled the cover off the back, and everything looks fine, no burnt electronics smell. Any ideas?
  • 3 more comments
  • Anonymous Jun 04, 2008
    yes i have the vs-50501a and when i cut my tv on it is totally black with sound
  • briarpatch Jun 04, 2008
    yes i have the mitsubishi vs-50501a and when i cut my tv on it has a black screen with sound.
  • Carl Jun 29, 2008
    OK, when i push the 'power' button on, the 'program timer' light (which is green) comes on for about two -three seconds and then goes out. There is no picture, or sound from the speakers, but there is a sound from the inside (not the speakers) when the power button is pushed, and it stops just as the light goes off too.
  • frode3 Jul 19, 2008
    my mitsubishi VS-50VA2 projection TV is missing 2/3's of the picture. Worked fine the last day we used it. Sound is normal.
  • Dean T Oct 06, 2008
    I have an older 57" Mitsubishi rear projection TV (2000). Today I was changing the channel and the picture went out. Still have sound, cable is working fine, just no picture.
    What do you think it is?
    Problem Solver:
  • 4 Answers
Check the heater power supply. you can find it at the CRT cuircuit at the back of the Picture tube. labeled H1 and H2 check the resistor Bias or re-heat CRT socket.
Posted on May 07, 2008
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
TV was working fine and then the picture has totally gone, just a Black screen as though it is switched off, Audio on all channels are fine and turns over as normal. No Text no nothing on the screen...
step 1 : at first test your fly back transformer
step 2 : A.C. transformer test
step 3: adjust TV yoke coil
Send report
Jul 28, 2011 | LG 50PS60 50 in. Plasma HDTV
Hi, I have a Canon T2i Rebel. When i put the camera in "M" (totally manual), the image doesnt appear in the LCD screen. Everything else works fine in the monitor, but it is as if the lens where...
That's great news, so let's write it up as a solution so that other people who search on here find the right information!
So it appears that the Canon T2i when in manual mode (M) remembers whatever settings you play with, and that these settings are remembered across power cycles; in other words, turning the camera off, or switching to auto before going back to manual does NOT put the settings back to a default.
This gives you the opportunity to set choices that make the screen view totally white or totally black, and unless you realise what you did, you can fear that your camera is broken in some way. At first, I thought this was a user interface flaw, but at least with the screen black or white, you know which way you need to go to get your picture back! The settings that affect brightness are Shutter Speed, Aperture Value, and ISO Rating. They are accessed in manual mode with the thumbwheel, alone, with Av, and after pressing the ISO button, respectively.
One more little bit of trivia: when in manual mode if you don't have live view on, when you half press the shutter, a little indicator comes up on the exposure scale, so that you can see how the settings you've chosen are going to come out.
P.S. I noticed that there was a forum especially for your camera, you might like to join it, it's called t2iforum dot com.
Jan 24, 2011 | Canon EOS 550D Rebel T2i Digital Camera
I can turn power on and i will get sound but no picture. I can get different channels up & down with sound only ,but no picture. It seems that the picture has totally failed as there is no on screen...
This can be caused by a main board failure or a t-con board failure. There is a fuse on the t-con that fails but it is not the standard looking fuse. It is an extremely small, surface mounted component fuse. You have to know what you're looking for to find it. It can be bypassed momentarily and if the picture comes back then the t-con is the problem for sure. You really ought to take it to a shop as this is not something that is easily diagnosed at home.
Aug 28, 2010 | Olevia LT42HVi 42 in. LCD Television
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
A solid black block covers majority of screen - all else works
Try turning off the text box function of the closed caption decoder.
Sep 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Nikon s6 coolpix
I would check with Nikon and see if it's covered under warranty still. There could be something going on with the CCD unit
Jun 14, 2008 | Nikon COOLPIX S6 Digital Camera
Samsung HL-P5663W, picture goes black after some time
I fixed it. Went back in after a twenty min. break, figured if it's broke I can't break it again, might as well try to fix it(out of warranty, so much time on 1st. bulb, after fixing I found out had 8463 hrs. on 1st. lamp! WOWW most i've seen on any strings out there,and I'm really cheap and inquisitive) But this is how I did it. pulled off covers. looked around pulled light box out checked connectors and resistors visually for burns, none found, then I see a clear plastic sleeve covered group of wires it was plugged up at the ballast where i was working earlier but not the other end, so i looked around for the plug to insert it, couldn't see any where. I felt on top of a silver polished panel w/holes allover, there on top, at the right side of the silver panel was a plug for it. I plugged it in by removing fan and cooling fin assembly, for room to work(and good chance to clean dust from the fins and fans. I tilted silver panel down to see the top, after some removing spring loaded screws holding cooling fins, (the screws ave very light spring tension and won't pop out, I swear, keep track of springs for reassembly later) plugged it in(only goes one way, don't force it, flip over if it doesn't fit nicely) replace all removed parts in reverse order and reinstall covers, plug up, and mine powered on almost instantly. After that and spending 2 hrs. online trying to go through all the strings everywhere about these problems. It came down to trial by fire. I hope this helps, reply if it doesn't.
Oct 31, 2007 | Samsung DLP HL-P5663W 56" TV
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Televison & Video Logo
119 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
