Question about Creative Labs ZEN Vision:M Digital Media Player
Unable to switch on
Status All software loaded on Computer
Wanted to charge mp3 using usb socket, the mp3 was about a quarter charged.
Mp3 switched on but was not recognised by system and charging icon
did not indicate charging
Removed mp3 from usb and it stayed on but was unable to switch it off by any method
eventually using a paper clip I reset the mp3 via reset buttoon, this tuned off mp3 for good, never to switch on again.
A week later tried the mp3 again it would not switch on so I connected to usb still did not come on. Ileft mp3 connected to usb for 2 hours during which time the blue lite next to on/off switch flashed continuously.
Has anybody any suggestions on repair?
  • 608 Answers
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Posted on Mar 28, 2010
Can u please tell me how to charge my mp3 player Laser 2G ? its new and they told me that it will be charged when i put it in my computer but i tried and i could not even while my computer is charging .
The MP3 player is charged using the supplied USB cable. When you connect the USB cable into the computer's USB port when the computer is switched on.
If the MP3 player still does not charge, try connecting it to a different computer. If it still does not charge then the USB cable may be faulty.
I suggest you take the MP3 player back to the supplier for a replacement. You should get them to test the MP3 charging.
Jan 09, 2011 | Laser MVP-2G (2 GB) MP3 Player
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
When I switch the MP3 player on on the screen appear TELEFUNKEN and then it automatically switch off again. I checked the battery and it is fully loaded. When I connect the MP3 to the socket with the USB...
When I switch the MP3 player on on the screen appear TELEFUNKEN and then it automatically switch off again. I checked the battery and it is fully loaded. When I connect the MP3 to the socket with the USB cord to charge the battery on the screen appears the following: IDLE and some kind of symbol. Can you please help?
Dec 16, 2010 | Truly MP310 MP3 Player
I ahve a no name mpe player and try to sart it and it just comes up with the loading symbol but will not go any further
Hi there
Flip the MP3 player's "Hold" switch to "Off" if the switch is on. Depending on the MP3 player you own, this switch is likely located at the side or top of the player. Once the switch is off, try to turn the player on.
Let the battery of the MP3 player die. A frozen MP3 player is technically still running, and thus the battery for that player is being drained. Wait until the battery is fully dead before moving to Step 3.
Charge the MP3 player using either a computer (that's turned on) or an electronic MP3 charger. Charging the player's battery may "jolt" the player out of its frozen state. Connect the player to the computer or charger via the player's USB cable. Charge the player for 30 minutes before attempting to turn it on.
Sync the player with the appropriate software program (for example, Windows Media Player) for the MP3 player. Connect the player to the computer as described in the previous step. Open the software program and click the "Sync" tab at the top or side of the program. If necessary, click "Start Sync" underneath the tab. The name of the player appears under the "Sync" tab if the player has synced successfully. Try turning the player on once it has synced with the program.
Press the small "Reset" button on the MP3 player. This hard reset shuts the player down completely. Use a pin, tack or thin nail to press down the very small "Reset" button on the side or back of the MP3 player to reset the player. Then, try to turn the player on.
Sep 16, 2010 | Jwin MP3 Player
My sansa fuze i plug it in to the computer and it doesn't recognize the device and i have tried all usb options on the device. What do i do it wont charge at all.????
When the Fuze can be switched on:
1. slide the power on switch shortly upwards to put the player on
2. hold the power on switch upwards for 15-20 seconds
3. release the power switch
Next try to switch the player on and see if it reacts normally.
Switch the player off again and try charging again, making connection to a computer.
When charging still doesn't start, disconnect the player from the computer:
4. slide the power switch downwards into the lock position,
forcing MSC mode
5. connect the player to the computer for charging in MSC mode
for a about 3 hours.
6. while charging use the Sansa Firmware Updater to check for
updates. When not installed already download the Sansa Updater
and run this execute file.
Updates for the player can only be performed in MSC mode.
The updater only works when you're logged in to the computer having administrator's rights and running Windows operating system.
MSC mode means that the computer sees the player as a removable disk. When in MSC mode, always disconnect through the icon "safely remove hardware" in the right corner below of the computer screen.
When the display of the player doesn't react at all after the reset and charging procedure, the battery of the player can:
a. be too far empty or
b. have a fast power loss.
The load of the power supply from the USB ports might be to weak to get the player charged.
When point a. is the case, an extra power adapter connected to a wall socket, providing more power, could help.
When the battery has had many loads it can be at its end of duty cycle. Then battery replacement will be required.
Need more help ? Just post a comment.
Dec 27, 2009 | SanDisk Sansa Fuze MP3 Player
Really i don't know what the problem is. the creative doesn't charge and when it charges don't do anything
the player seems to need longer charging:
1. while player switched OFF: let it load on ac-adapter or USB-connection**** for about 1 hour, until the screen lights up.
2. still while player switched OFF: let it load another 2 to 3 hours
to get it fully charged.
**** notice: when using USB for charging:
1. Install the application software (from CD or Creative-download)
2. Preferred is a USB-connection at the backside of the computer
3. When more USB-connections are used, have the others disconnected: trying not to overload the USB-port power-consumption.
Support for Zen Vision M on the site of Creative:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=14331&prodName=ZEN+Vision%3aM
Aug 12, 2009 | Creative Labs ZEN Vision:M Digital Media...
Can I use a wall charger on a COBY 705 4G?
Yes, However it will show up as a USB cable but hold the power switch and will begin to charge. You also can use the player while it charges that way!
Apr 24, 2009 | Coby MP-705 Digital Media Player
Not charging and down loading form computer
Just had the same problem, found solution on another thread
Switch Off
Put side switch to hold
Press in middle button, keep holding in while you plug into usb port and keep pressed for a few seconds after.
Computer should recognise it and will keep charging.
Worked for me
Feb 04, 2009 | SanDisk Sansa e260 MP3 Player
Unable to charge battery on Audiophase MP3, model KZ111
Try using the AC charger for the mp3 player, If It does the same thing, Ur MP3 is defective and u can return it with out the receitp sayin that it was a christmas gift since most eleftronics have a 1 year warranty
Feb 07, 2008 | Audio Players & Recorders
Charging the coby clip 1gb m582 mp3 player
the manual says something about turning the player on when inserted into the usb port so it  can charge
Jan 06, 2008 | Coby MP-C582 MP3 Player
Creative Labs ZEN Vision:M Digital Media Player Logo
162 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
