Crash My PC starts but doesn't get into OS. It fails to load and then asks to be shut down. Before this a cleaning started out itself and removed a few components. It also made and makes grinding noises. Is it necessary to buy a new harddrive? And if so, which one? Thanks.
  • 88 Answers
You can use a ide drive
Posted on Dec 12, 2009
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
Upgrading from vista to win7
I would start by deleting partitions and doing a full format. Then loading an OS. Check MS minimum system requirements for OS and double them.
If it crashes again. Start checking RAM.
Sep 27, 2012 | Dell Computers & Internet
Hello i have a compaq presario sr1703wm. the pc crashed due to a virus. I got the virus off or its seems to be gone. but if i shut the system down and reboot and try to run system recovery to reset to...
learn now,. that no 1 virus cleaning actions works even 1/2 the time once infected.
its like driving car with flat tire to store to buy a new tire.
impossible or just all bad news end to end.
that is true. even running 10 AV scans can fail. ask any one that had to do this for years, yah
there is only a few real cures. that are 100% effective.
from 100% to least effective order
1: HP magically F11 key, back to day 1 recovery, do that?
2: buy the HP media kit, (above is missing before 2006?) and install your unstated OS fresh.
3: use MS media and spend a week fining lost drivers.
4: remove the HDD and put in on other PC, as 2nd drive.
or better external usb drive case.
and run 10 AV scans on it, the top 10 brands, one is ESET offline scanner.
those are the ropes
the F11 recovery fails if :
A: someone deleted all files on PC and loaded MS OS.
B; the HDD was ever change out.
C: or if super unlucky the virus infected the F11 partitions, too.
you are infected still or has aftermath.
F11 key , and pick startup repair.
if this fails do full recovery
if that fails see step 2 above.
Jan 16, 2018 | Compaq Presario SR1703WM PC Desktop
Error appears after start-up and shuts itself down.
has the game ever crashed while saving? have you downloaded any mods/patches for it?
Oct 30, 2009 | Legacy Interactive E.R. The Game for...
MAC PRO dual2.3- freezes, gray screen crash, freeze with hi fan mode,kernel panic reports, all require start button shut down. Some forums suggest ATI card failure. I'm lost.
All computers will shut them selves off or crash when fans are failing, or have failed. Cooling fans are plugged into the motherboard, and firmware on the MB keeps track of the system fans, along with everything else. If a system fan is failing, or has failed, the signal is sent to shut down. Some PC's will shut down cleanly, others give error messages, and some just freeze up. Of course, Bad RAM, video cards, and hard drives with bad sectors, can also cause problems like you have discribed.
I would write down any error messages, and beep codes, and then look them up online for a place to start.
Oct 22, 2009 | Apple Power Mac G5 Desktop
My computer crashed, so I wiped it clean and started over. I down loaded the software but did not pull the card out first. Then I uninstalled the software, shut the computer down, removed the card, turned...
if your problem is your computer crashes due to wireless adapter card.. try turning off your pc and remove the card, then boot your pc.. and see if it still crashes
Oct 19, 2009 | Cnet CNWL-311 802.11b (CNWLC-311) Wireless...
Laptop shut downon its own
Your fan has failed! Your cooler not working properly, clean your cpu-fan. Your CPU is over-loading temperature is too high without an working fan! This is your Problem!
Sep 03, 2009 | Lenovo 3000 C200 Notebook
M9700 starts up but shuts down few minutes after vista loads
Sounds like it is a problem with the m9700 overheating. I have just repaired an m9700 with this exact issue and it was resolved by taking the CPU heatblock off, removing the dried/caked-on heat compound, and replacing it with my own (Arctic Silver 5).
Was 91c before, now down to 74c max on load (Measured with coretemp). Random crashing has stopped.
Sep 03, 2009 | Alienware PC Systems Alienware Aurora High...
Dll driving me nuts
Hello EricS777
The part where it looks like your xp stuff and vista stuff switch drives is normal. Only the Operating System associates the hard drives by letters this does not mean your hard drive files are switching. This happens because D: drive is Root of Vista OS and Root of any OS in windows gets the C: drive lettering.
dwwin.exe, drwtsn.exe dll is the "Microsoft Application Error Reporting" tool.
I think the message means that something is crashing during system shutdown. When the crash occurs the OS launches dwwin.exe to report the error, however the windows operating system is shutting down and so the application can't launch make the system lockup or hang.
Your problem isn't with dwwin.exe, you need to find out what is actually crashing at shutdown.
If you can`t find out what it is, try going to Administrative Tools/Services and disable the “Error Reporting Service”. You don`t want that running anyway.
Also right click My Computer/Properties/Advanced/Error Reporting
Put a check at both
Disable Error Reporting
But notify me when critical errors occur
Then, if that was the cause and the message stops, we`ll have to try to identify the cause.
May 05, 2009 | Acer Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
