Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
No convergence option on set up
I need have the convergence reset but my particular model does not have that option under "set up options". Tech support said I had to call and pay someone to come out and do it for me. I know I did this at the iinitial set up.... is there a way to get back to the "initial set up" when I first got the tv
  • bullweavel Dec 20, 2007
    well it made me do it when I first initially got the tv. It automatically went that area and made me do it before I could do anything else. There was a red,blue and green cross. It had me put one on top of the other. Now that this problem has come up, the RCA call center instructed me to go to the convergence tab under the set up menu. Mine does not have that option and I dont know if it ever did. Isnt there something I can do that would make the set act like it has never been turned on before, thus when I turn it on for the "1st time" again, it automatically directs me to resetting the convergence
    Genius:
  • 1,030 Answers
You might have a problem.. under setup in the customer menu there is no convergence option. What model do you have. Is the set completely without Convergence?. There is a special fuse in certain models that if blows the processor. tells the set that the set is not a projection so it doesnt need convergence. and removes that option. THe fact u refer that you did this in intial and dont see it now is what makes me suspect this.
Posted on Dec 19, 2007
  • Willie Howell Dec 20, 2007
    unplug the set for 30 min... if u dont have the convergence setup option then i suspect you have blown that special fuse. what is the model of this set
Audio but only black screen for video on WS65807
First, the set has a hard reset but it will NOT affect convergence which is stored in a separate area of the set.
Model indicated has 3 hidden menus---all accessed with the Original remote and a 4 digit code.
At your own risk:
This is a V17 chassis that was used in 8 models.
It has 3 hidden tech menus: With set on:
Option menu is 8270 enter---The Option menu reset will return all settings to factory and also will clear any glitches out of the way--it as stated can cause Convergence not to be affected.
Circuit adjust menu: (stay out as one wrong move and fatal things can happen is : 8257 enter.
Convergence adjust menu: (better than customer and SAVES adjustments made in to the DCU or digital convergence unit in the set.
I STRONGLY SUGGEST YOU TRY THE OPTION MENU FIRST, IF NEED DETAILED INSTRUCTIONS I CAN LOCATE THEM FOR STEP BY STEP OF THAT.
SEE IF IT CLEARS THE MAIN ISSUES UP FIRST---IF YOU TRIED TO ADJUST CONVERGENCE IT MAY NOW BE MESSED UP BUT UNLESS YOU GET THE SET BACK TO WORKING SOMEWHAT NORMAL NOTHING TO WORRY ABOUT.
keep in mind I do this here for free and have worked on hundreds of these Mitsubishi sets.
SD TECH------ASK BEFORE YOU LEAP!
Dec 02, 2012 | Mitsubishi WS-65807 65" Rear Projection...
NO PICTURE!!!! Please HELP! I am going to kill my husband for bringing this TV home!
If the model number is correct and all you can get is the menu or on screen displays to work the set may need to be reset--not on the front or in the menu.
The set has 3 hidden menus: adjustment (keep out), tech convergence, and the OPTION menu.
Option menu enables a hard reset to factory of all settings except convergence and is designed to fix odd issues.
You need the Mitsubishi remote and a 4 digit code (model specific).
If you have the remote and want to try it let me know what the actual model number is and I will give you a link to the service manual which tells how to do it correctly.
SD TECH
May 30, 2012 | Mitsubishi WS-55857 55" Rear Projection...
How to reset factory defaults
I will presume you have the model listed here and have the Mitsubishi remote in working condition.
These sets have 3 hidden menus: Adjustment (stay out of that one), Convergence, and the OPTION MENU.
The option menu is the one you would want--it requires that you turn set on--enter a 4 digit number that is model specific.
In the option menu you can do a HARD reset which puts everything except convergence back to factory (that is stored in another area).
The reset puts all settings back to factory--set will come on once done on channel 3 in air band etc.
Let me know model number here is or is not correct and I will give you a link to the service manual with page number to look at---explains how to do the reset. Not a bad idea to save that manual as it contains all kinds of good info on this set.
SD TECH
May 26, 2012 | Mitsubishi WS-65411 65" Rear Projection...
How to reset factory settings ws 65517
If you contact Mitsubishi the set has three hidden menus---convergence adjust, circuit adjust and OPTION MENU.
Each model uses a four digit code with menu and for example 4750 and in the Option menu is the option to do the hard reset for the set---
The wipes all labels (dvd etc) and puts set back to default on all factory settings.
You might find it if you GOOGLE THE MODEL NUMBER with option menu after it...........
Mar 18, 2012 | Mitsubishi WS-65611 65" Rear Projection...
How do i reset my mitsubishi television model#ws-55511
First a reset may not help unless I know what your problem is.
If model listed (WS-55511) IS CORRECT: set has 3 hidden menus:
Option Menu (hard reset of all settings to factory)
Technical Menu (Adjustments for various things)
Convergence Menu for adjusting convergence.
THESE ARE NOT ACCESSED FROM CUSTOMER MENU. Each requires Mitsubishi remote and a 4 digit code .......
So, What is your issue with the set?
I have the codes but it depends on model number and what problem with set is, reset is in Option menu but will not cure all problems.
SD TECH
Nov 10, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
  1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  2. Enter the menu on your TV. Use the remote control and bring up the menu.
  3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  5. Press "Enter." A crosshair pattern will appear on your screen.
  6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  9. Repeat these steps for all colors.
Take care
Jul 06, 2010 | Televison & Video
Can not align red even though convergence board WS-55819
Did you replace the center board with the STK-392-570 chips or the Digital convergence board mounted on it?
98% of the time if you have a convergence problem it is on the center board---the small board on the left under the metal shield box stores and controls the convergence of this set.
WHICH DID YOU REPLACE?
I am here to help----I have fixed hundreds of Mitsubishi sets with convergence troubles.
Regards, SD TECH
Oct 28, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Convergence needs to be reset.
thats a easy and inexspensive repair. there is a repair kit called the ITC222 and ITC222A convergence option missing repair kit which will usually fix that issue. You can get the kit which has the parts and detailed instructions at the following link. www.tvrepairworld.com under their RCA repair kits category.
Aug 08, 2009 | RCA HD52W59 HDTV Projection Television
HD RCA TV NEEDS REPAIR
Let see if i agree with the tech. first question what does the picture look like. Second in customer menu under setup do you have the "convergernce " option in the menu if not it might be a simple inexpensive repair known as fl231 fuse. if you have the option try autoconverging see how far it gets. does the picture bow in from the top and bottom. there are three possible cuircit boards that effect convergence. And it takes a technician sometimes to adjust... let me know and will continue to troubleshoot this down
Oct 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Adjusting convergence
try unplugging and waiting over night and then repluging it in this will reset the computer
Feb 20, 2007 | RCA P52928 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
