Question about HP PSC 1610v All-in-One Printer
I have tried all recommended solutions for clearing the message "remove and check right cartridge" - reset, cleaned, etc....any other options?
    Sniper:
  • 70 Answers
Replaced the cartridge.
Posted on Sep 29, 2009
I have an error message B200
Hi Kathleen,
to clear the Canon B200 error code:
Steps for 4+ Cartridge Printers
  1. Remove All Cartridges. Do whatever is necessary to remove the individual ink cartridges from your printer. In most cases this will be opening the lid of your printer and waiting for the cartridge cradle to move into the correct position.
  2. Remove the Printhead. This is easily achieved in most printers by simply lifting the orange/gray locking lever on the side of the cartridge cradle and then gently lifting the printhead from the printer.
  3. Reinstall the Printhead. Gently put the printhead back into your Canon Pixma printer and lock it into position firmly.
  4. Reinstall All Cartridges. Place all of the cartridges back into the printer and close any open doors. This makes sure that your printer is actively examining the reinstalled cartridges and printhead.
  5. Unplug the Printer. Physically remove your printers plug from the wall and leave it unplugged for 5+ minutes. This allows the printhead to cool and all residual electricity to leave the printer.
  6. Plug the Printer Back.
  7. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
Steps for 2 Cartridge Printers
  1. Turn the Printer off. When your printer is in this error state it will not let the cartridge cradle within the printer move. However resetting the printer should clear the error message temporarily allowing us to troubleshoot further.
  2. Turn the Printer Back on Again.
  3. Remove the Problem Cartridge. Whilst the Canon Pixma error messages do not tend to specify which cartridge is causing the problem, you should be able to have a rough idea based upon which cartridge was last replaced.
  4. Install a Replacement Cartridge. As the printhead is part of the cartridge, sadly there is no way to stop the B200 error without replacing the cartridge. I would recommend either installing a new cartridge or a previously used cartridge that you know to be functional.
  5. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
  6. If Necessary Replace the Other Cartridge. If the error persists with the new cartridge, it may be that the other cartridge has developed a fault and is the cause of the B200 support code. If at this point the error remians I can only recommend replacing the other cartridge.
Aug 11, 2017 | Office Equipment & Supplies
HP PSC 2175 says remove and check cartridge.
Might be one of the cartridge faulty, resit one by one find out faulty one replace it..
Jan 01, 2012 | HP F-450 Office Equipment & Supplies
I have tried a couple of the recommended solutions from this site but still to no avail. My HP all-in-one has a flashing message that indicates to check my right cartridge, which is the black cartridge. ...
Did you try to Reset the printer?
1. Unplug the power cord from the back of the printer while the printer is on
2. Now press and OK and Cancel button at the same time
3. While holding them plug in the power cord
4. Release the buttons when the printer turns On
It will reset the printer and you will see the message on the LCD also.
If this also did not help then try another cartridge and if that also does not help then there may be hardware issue with the printer .
Though still let me know what happened
Apr 17, 2011 | HP PSC 2410 All-In-One InkJet Printer
False paper jams--tried cleaning, reset, etc. Nothing seems to work
Have you tried this method? (listed below), if not, give it a try.
Remove all the cartridges, clean the contact points on the cartridges and on the printer using soft brush/cotton dipped in alcohol/acetone /spirit.
While they are drying, reset your printer; Turn it off > Disconnect usb cable, power cord, inthernet cable; >remove the papers from the tray >open the back panel door (the rear door where you clear paper jam). Also turn of the main switch which the dc adapter plugged in. After keeping it Off for about 5 minutes, turn on again using only the power cord, and again leave it on for few minutes > turn it off > connect all the cables > again turn it On and keep pressing the power button while it boots up. Now you can install the cartridges.
If there's not internal problem or wrong cartridges number, then your problem will be definitely fixed.
Good luck.
Thanks for using FixYa.
Aug 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
Problem started when I installed a new black cartridge, which apparently didn't fit properly (it was loose and didn't click into place). Printer kept trying to calibrate for new cartridge, but wouldn't...
Hi, Pls plug it to power and open the cover to replace cartridge. After that remove power cord & remove cartridge. Clean slot & printer head.
(it may also happen that u do not have a good original)
Feb 06, 2010 | HP PhotoSmart 7960 InkJet Printer
Message says remove and check cartridge
The cartridge is not making contact correctly.
See this article & this one from HP support to clean the contacts and reseat the cartridge. Make sure to allow the contacts to throroughly dry after cleaning, both the ones on the cartridge and those in the printer, then turn the printer on and reinstall the cartridges with the machine on. Press enter to align the cartridges and scan the alignment page.
If this procedure does not clear the error, and you have carefully cleaned the contacts and the cartridges are fully seated, try resetting the printer according to these instructions.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 5510 OfficeJet - error message "Remove & check color cart"
check all areas for any paper jam, also check the feed roller in the paper trays if the roller are slick with paper dust, clean them and then reinstall the paper. Sounds like a paper sensor is not been cleared. then the error message, should go away on reboot.
Mar 16, 2009 | HP Compaq Evo Notebook N600c
"Clear paper jam" error, but there is no jam!
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
May 25, 2017 | Epson Stylus Photo RX620 All-In-One InkJet...
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Try cleaning the rollers, it's the maintenance tab on the printer's properties. Maybe this will help.
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
HP PSC 1610v All-in-One Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
