Msi ms-7082 motherboard problem
Power off after entering bios setup. i am thinking the problem is the mother board.? is ther any diagram available for the mother board?
proton77
  • 1183 Answers
SOURCE: reset bios on MSI ms-7301 motherboard
Kindly visit the following site
http://www.msi.com/index.php?func=downloadindex
Select the correct model number for your mainboard or motherboard and download the user manual for the same. It has details on how to reset the cmos or the board using the jumper settings
Thanks for using fixya
proton
Posted on Aug 15, 2009
map9966
  • 2351 Answers
SOURCE: msi motherboard for model k8t neo ms 6702
Its the model numbers that vary the most when looking for the manual. Click on the link below to open MSI download site;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+NEO&table=download
While on MSI's site I searched for MS-6702 and left out the term, "K8T NEO". MSI provided the another link; http://www.msi.com/index.php?func=searchresult&keywords=MS-6702&table=download
The model numbers K8T Neo-FSR and FIS2R, use the same manual.
See link; http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565
K8T Neo2-F and FIR use the same manual.
From the pic included, Connect everything to JFP1. Connect the speaker to JFP2.
b972b2a.jpg Wire colors do vary from case to case. Normally solid colors like red, green, blue and dark blue are used as positive. White and black are negative. Each jumper pair will share a common color. That common color is negative except when hooking up the speaker wire. Black is used for negative.
Cheers!
Mike
Posted on Oct 25, 2009
SOURCE: REPLACING MSI MS-7184 MOTHERBOARD - WHAT IS CORRECT REPLACEMENT
What the pins for the power switch, HHD indicator light, power light, and reset on an MS-7184 Motherboard.
Posted on Aug 06, 2010
SOURCE: msi ms 7071 motherboard driver
i need ms-7071 all driver
Posted on Jan 28, 2011
  • 77 Answers
SOURCE: mY COMPUTER HAS MSI N1996 MS-7507 VER:1.0 MOTHER
MSI 945GCM7-F (Msi ms 7507 ver 1.4)Motherboard Drivers
Posted on Feb 28, 2011
How to install bios
the bios is already on the board,
when you are booting the computer you have to push down on the F10, if that doesnt work than try F1 and thanF2, every time you try to enter the motherboard bios you have to start from a cold boot.
website for motherboard bios configuration and settings is at
http://www.msicomputer.com
if you want a copy of the bios setup and configurations and everything explained in detail go to your browser and type the following information.
MS-6758-040 BIOS MANUAL OR
MSI MS-6758-040 BIOS MANAUL
the bois controls everything the that runs you computer, video, ram, HD, CPU, PORT FUNCTIONS, BOOT SEQUENCE, SMART FAN CONFIGURATION, HD CONFIGURATION, TEMP. SETTINGS, AND ALOT MORE STUFF AND VERY LONG LIST.
MAKE SURE THE BATTERY IS MIN. 3VOLTS
Jun 25, 2014 | MSI MS-6758-040 Motherboard
Mother board can not see any device just bios
are all the cables plugged in right check all ribbons and power cables one by one make sure the red line is on the right way and the same as the power lines.
Jan 15, 2014 | MSI MS-6380E (MS-6380E-010) Motherboard
Ms 7082 ver 1 vga drivers
ms-7082 ver:1 vga driver i want a free d load
Apr 07, 2013 | MSI K8MM-V Motherboard
I have a MSI K9MM-V(MS-7312) mother board installed running on MS XP Professional, I wanted to temporarily boot from my CD/DVD drive how do I accomplish this?
Just go to bios setup, click "delete" or "F2" when the system started to boot up, go to boot set up and select "cd rom drive" first boot, save on exit. It restart w/ the cd rom drive first.
Hope that helps you out.
Sep 13, 2011 | MSI K9MM-V Motherboard
Need a msi ms-7312 ver 1.0 vga driver
Hi, Your driver can be downloading easily by using this: Driver Update Software. take a look, and wish you best of luck. Hans
Oct 02, 2009 | MSI K9MM-V Motherboard
I need the setup diagram for a MSI K9N6SGM V2 #MS-7309 MB
Hi James,
As I can see here that you need the jumper setting specifications for your motherboard K9N6SGM V2 #MS-7309 with a single IDE port.
Even this is for version 1 the layout for the Jumper settings are still the same with your version 2 motherboard the only differences with version to are the changes on the support and bios version
Link:( Manual)
http://www.msi.com/index.php?func=downloadfile&dno=4212&type=manual
Jun 16, 2009 | MSI K9N6SGM-V Motherboard
MY msi 7082 cant read HDD 40GB and above whY>?
Your board specifications are here - http://www.msicomputer.com/product/p_spec.asp?model=661FM3-L&class=mb
This sounds like a memory timing issue based on the caution from the MSI page. There is no reason the board itself should have a problem with that size hard drive. Have you reset the bios to factory default and tried the various compatibility settings available in the bios?
Dec 26, 2008 | MSI 7082-010 (661FM3-V) P4 LGA775/SiS...
MSI MS-6541 Motherboard drive
i need sound driver of mother board motherboard MS-6541 VER :1.0
May 09, 2008 | MSI MS-6547 Motherboard
Computers & Internet Logo
1,736 people viewed this question
David Payne
David Payne
