Question about Samsung HCM4215W 42" Rear Projection Television
HCM4215W Green convergence problem
On my Sanyo TV the green convergence is out of whack. The verticle green line when adjusting auto focus is bowed no straight. You can adjust it on at the top and bottom, but its WAY off in the middle. The red and blue look OK. I Have the service manual for it, but no experiance with rear projection and don't want to put much into it.
Thanks
Greg
I have a red line going across the screen
Posted on Jun 17, 2008
    Novelist:
    Champion:
  • 211 Answers
Hi Greg,
Sounds like you have a bad convergence chip in the convergence board. Unfortunatly, about 80% of the rear projection sets I work on have this similar problem. I suggest that you change both chips ( there are 2 of the same ) and remember to use heat sink compound as this is why you not have the problem ( excessive heat destoys electronic components). Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
Green verticle line on right side of image
Your color convergence is out of adjustment. You can adjust yourself with a service manual telling you how, or take it to service shop and pay about $400.
Jan 17, 2010 | Sanyo PLV 60HT Multimedia Projector
Mitsubishi Convergence issue
If the screen is out of focus you probably need to adjust the focus on the focus block it is usually located behind the front grill, there are 6 adjustment screws on this block, leave the screen controls along just adjust the red, green, and blue focus screws. When converging a set everything is converged to the green, the blue and red are suppose to come to the green.
Sep 02, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Green Out Of Focus
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 30, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi 43FDX01B green is out of whack
The green is not adjustable in the customer menu because it is considered the 'master' color. It is adjustable in the technician mode however but if it is curved it won't even adjust properly that way either. The problem is the convergence ampifier responsible for green convergence has failed. The convergence output IC's need to be replaced.
May 27, 2009 | Hitachi 43FDX01B TV
Colors dont line up and green is "dancing" all over screen
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 15, 2009 | Sony KP-57WS500 57" Rear Projection...
Green and red lines
  • Screen looks 3D
0667c5f.pngSOLUTION
Mar 19, 2009 | Sony KP-57HW40 57" Rear Projection...
Is there a manual convergance on 53udx10b
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 06, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Have green bow in top right and green shadows all over
your convergence board needs to be replaced..its out.thats why the bow in the pic
Oct 30, 2008 | Hitachi 46F500 46" Rear Projection...
43F300 convergence
Convergence kit # X480306 for your Model #.....
Replace parts & activate auto-focus......T.
Sep 01, 2008 | Hitachi 43F300 43" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
75 people viewed this question
Jerry Greenberg
Jerry Greenberg
