Question about Euro-Pro Shark GI490 Iron
The iron is on but the bottom is not hot why? every thing else is working but not the the part where you would press with and now we have no iron
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
How can I clean a burnt mess on the bottom of the iron
Baling soda water paste. Vinegar in hot iron. Oven cleaner on cold iron, turn on, when hot wipe with damp cloth.
Dec 16, 2011 | Irons
Tip
Cleaning a Steam Iron Soleplate
During the day to day use of a steam iron there can be normal buildup accumulate on the soleplate of the iron. Other things such as melted synthetic fibers, iron-on trims, and fusibles can also buildup on the sole plate of the iron. These can be removed with the use of a quality hot soleplate cleaner. Soleplate Cleaning Kits can be purchased from many service centers or can be found online by doing a search for “soleplate cleaning kit”.
If you have had the misfortune of getting melted plastic on the soleplate of your iron, you can remove that by taking a piece of Aluminum foil and sprinkling it with salt. Then take the hot iron and work it back and forth over the salt to break up the plastic and remove it from the bottom of the iron.
Avoid starches and be careful of synthetic materials. Also avoid zippers and buttons that can scratch the bottom of your iron.
Do not use the soleplate cleaners on your iron if it has a non-stick surface. With the non-stick surface you should not need the cleaning anyway. These surfaces can be damaged easily by anything abrasive. Do not use abrasive cleaners on any soleplate. Use the soleplate cleaning kit.
The holes in the bottom of our iron can be cleaned by using a pipe cleaner of a Q-tip.
Simply make sure the bottom is cool and then insert the pipe cleaner or Q-tip into the holes one by one and circle them around inside to clean out the hole.
If your iron has a “self clean” feature, do not over use it. It is recommended that you use it at least once per year, but not more then once per month.
Also look for my other tips on taking care of your steam iron.
on Jul 14, 2010 | Irons
How to cean bottom plate with spray starch on it
Rowenta has a cleaning kit found where the irons are displayed.
Faultless Hot Iron Cleaner can be found in the laundry area.
Dritz Iron-Off is with sewing notions.
You can also use a damp cloth dipped in baking soda, but the above listed cleaners will work faster and better.
Apr 08, 2010 | Rowenta Effective DX1900 Iron with Auto...
Do i need that stand to make this iron work? nothings happening. lights are the only thing that works!
Does the owner's manual specify? It should. Usually those stands just give you a place to put the iron out of the way so you don't have to lay it flat on the ironing board while it's hot.
Jan 29, 2010 | Oreck Cordless Speed JP8100CA Iron
Iron leaks water while ironing
Seal on iron is disolved. replace iron
Aug 31, 2009 | Rowenta DX6700 Iron
SHARK STEAM STATION G6200 SUDDENLY STOPPED WORKING.
take it back to the store and tell them what has happend the only thing i can think of is that one of the wires has come loose within the cable
Apr 21, 2009 | Euro-Pro Shark GI490 Iron
DM880 Rowenta Professional Luxe Iron
The thermostat is bad...
heatman101
Jul 20, 2008 | Rowenta Professional DE880 Iron
Premature shutting off
the only thing you can do is change out the motion sensor which is 1n the machine or disable it
Apr 21, 2008 | Irons
Water shooting out bottom holes
This normally means that the iron is not heating up enough check that you have adjusted the temp so it is not as the water will either come out of the bottom when not hot enough to steam or when the jets get dirty and need cleaning.
Thanks J
Feb 12, 2008 | Euro-Pro Shark GI490 Iron
Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
Euro-Pro Shark GI490 Iron Logo
166 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
