Question about Dell Latitude D830 Laptop Computer PC Notebook
My laptop is having trouble connecting to any internet source whether its wireless or dsl.. how can i fix this
    Novelist:
  • 225 Answers
Need to isolate. do you have any other computer which is wired or wireless to the same modem or router where you trying to connect? if yes prove that other computer has internet connection. if both computers cannot connect to internet then call isp. if only one computer cannot go online then wired it first if fails try to check if laptop and modem communicates. if not then check network drivers if are installed. if yes then swap the externet cable you are using.
Posted on Oct 04, 2009
  • 112 Answers
For fix this problem u need to go in control panel in that u go network and internet and in that go network and sharing centre u find there add a device to network and u can add wirless network and your connection will be start
Posted on Oct 03, 2009
My D-Link dap-1160 is not working
For routers not just the power light that should be lit. Are you using a modem/router? If so, there should be a DSL,INTERNET,WIRELESS light indicator as well. If the DSL light is OFF,steady red, OFF there might be trouble with your line connection. Call your Internet provider. Also, check cables (yellow cord, gray cord, telephone cord) that should be connected tightly to where it supposed to be connected.
Feb 26, 2013 | D-Link DAP-1160 802.11g Wireless G Open...
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Nov 01, 2012 | Toshiba Computers & Internet
My lap top isnt set up for wireless connection to internet
Connecting laptop/computer to wireless router
If you have a wireless router and it is connected to the DSLor cable modem and Internet then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jun 16, 2012 | Samsung Computers & Internet
How do I use my laptop as an internet source for my wireless router?
You Internet access is through the cable or DSL modem.
Connect your wireless router to the cable or DSL modem and then configure the wireless router with the wireless encryption settings. Then configure the wireless cards in the laptops with the router's encryption settings etc. This will then allow the laptops to connect wirelesslt to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 05, 2012 | Linksys WRT Computers & Internet
I can not connect to the Internet. I have WiFi connection but can't do anything else
Plug your computer/laptop directly into router. Can you get to the Internet then?
If you CANNOT get to the internet when your computer is plugged into the router, reboot your router. If it doesn't have a power switch, unplug it. Leave it unplugged. Next, you need to figure out if you have another modem for DSL or Cable. If you do have another DSL or Cable modem, unplug that device to. After 5 minutes has elapsed for both devices being unpowered, plug in the DSL or Cable modem to the power source. Keep the router unplugged from power. After your DSL or Cable modem has powered up for 5 minutes, plug your router into the power source. Wait a few minutes. Reboot your computer/laptop. Try the wireless connection again.
If you CAN get to the internet when your computer is plugged into the router. Reboot your computer. Try to connect again. If you cannot connect after rebooting, make sure you are connecting to YOUR OWN wireless access point and not someone else's.
Do you have other computers/laptops/wifi devices that CAN/CANNOT connect to your wireless / access the Internet?
Jul 03, 2011 | Computers & Internet
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Fixing own wifi to dsl modem
I suppose you need to connect the internet using WiFI and not cable DSL . Please follow the below steps.
You need to have a Wireless router in place and connect the DSL to the router , then u need to give an IP to the router.
Configure your laptop to the router device.
Mar 31, 2009 | EnGenius EOC-3220 (EOC3220)
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Dell Latitude D830 Laptop Computer   PC Notebook Logo
169 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
