Question about HP Officejet Pro L7590 All-in-One InkJet Printer
The paper jammed while printing, and got message- The following printhead has a problem:Black/Yellow
technotech
  • 183 Answers
SOURCE: HP L7680 print head problem
Resetting the All-in-One
  • Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Posted on Aug 19, 2008
Techvisitor
  • 63 Answers
SOURCE: The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
Posted on Oct 31, 2008
  • 4 Answers
SOURCE: I keep getting the following
Only solution to this one (and I know) buy another printer. I had this problem a couple of years ago on an earlier HP Officejet and the solution given was to spend about $200 less to have it fixed than it cost; made it more beneficial to go out and buy a new one as the new ones cost a lot less than they did a year or two ago (plus this gives you the warranty). "thinks: Seems that all these problems happen just after warranty expires - ah wel......"
One of the most common events for this appear to be during change of cartridge(s) for the printer.
Hope this has helped somewhat
Posted on Nov 01, 2008
odiegh
  • 81 Answers
SOURCE: printhead problem (black/yellow) on HP L7780
When you removed the paper it's possible your damaged it and that's why the message is not going away. Did you try to put the cartridge back in to make sure it had not come out of position and just remove the power cord for a minute then plugging it back it.
Here are the steps to make sure you properly change the cartridges and the heads...
Install the ink cartridges and printheads Step one: Install the ink cartridges All four ink cartridges must be correctly installed for the HP All-in-One to work. Follow the steps below to Install cartridges:
  1. Open the ink cartridge cover.
  2. Remove each ink cartridge from its package.
  3. Align each ink cartridge with its color-coded slot and then insert the ink cartridge into the slot. To ensure proper contact, press down firmly on the cartridges until they snap into place.
  4. Close the ink cartridge cover.
Figure 1: Installing cartridges c00841893.gif 1 - Open the ink cartridge cover. 2 - Remove the ink cartridges from the packages. 3 - Install the ink cartridges. 4 - Close the ink cartridge cover. Step two: Install the printheads Follow the steps below to install the printheads.
  1. Open the top cover of the printer. Figure 2: Open the top cover c00848391.gif
  2. If the carriage does not move to the left automatically, press and hold the Resume button (c00847980.gif ) for three seconds. Wait for the carriage to stop moving.
  3. Remove the cardboard cover from the printhead carriage. Figure 3: Remove the cardboard cover c00848392.gif
  4. Lift the printhead latch. Figure 4: Lift the printhead latch c00848393.gif
  5. Before installing a printhead, shake the printhead up and down at least six times while the printhead is still in its packaging. Figure 5: Shake the printhead while it is still in its packaging c00847983.gif
  6. Remove the new printhead from its package, and then remove its orange protective caps. CAUTION: Do not shake printheads after the caps are removed. Figure 6: Remove the printhead from its packaging, then remove the orange caps from the printhead c00847984.gif
  7. Insert the printhead into its color-coded slot. The label on the printhead must match the label on the printhead latch. Press down firmly on the printhead to ensure proper contact. Figure 7: Insert the printheads in the correct color-coded slots c00847985.gif
  8. Pull the printhead latch all the way forward, and then press down to ensure that the latch is properly engaged. You might have to apply some pressure to engage the latch. Figure 8: Close the latch c00848394.gif
  9. Close the top cover. Figure 9: Close the top cover c00847987.gif
Step three: Align the print heads Whenever you insert or replace a printhead, the printer automatically aligns the printheads to ensure the best print quality. If the printer does not print the alignment page automatically, start the alignment process manually. To start the alignment process manually:
  1. Press the Setup button on the control panel Setup and the number 6 on the keypad or scroll to Tools .
  2. Press 4 on the keypad or scroll to Align Printer . The alignment process starts.
Posted on Dec 01, 2008
  • 298 Answers
SOURCE: my HP officejet Pro L7580 says the printhead has a problem
Re-insert the print cartridges. It is also possible that the heads are burnt. Get a new set of print heads (black/yellow) and install to the printer. If problem persists, clean the contacts on the printers. Use acetone + cotton swabs.
Posted on Mar 16, 2009
I am getting message "the
More black/yellow print head failure we observed in this series, no remidy for this issue replace the print head..
Sep 23, 2011 | HP Officejet Pro L7680 All-In-One Printer
Magenta and cyan will not print on my hp officejet pro L7590 -- it started with a paper jam that was corrected - ever since then only the yellow and black will print on the paper -- printheads are good and...
Same thing happened to my printer hp L7590. Printed diagnostic, only black and yellow printed; diagnostic for printhead health Ky=good, MC= good. Only Hp products ever used. Uplugged, & discharged static, cleaned copper parts of printhead. Still no fix. On visual examination of floor of printhead compartment rectangular pad ( approx 1/4" by 1/2") is missing. I can only guess that during the paper jam, somehow the pad got caught up and went awol. Not sure what to do now.
May 26, 2010 | HP Office Equipment & Supplies
My HP officejet Pro L7580 says the printhead has a problem
Mar 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Printer: HP OfficejetPro L7680 ALL-IN-ONE immediately after a paper jam, my printer screen says "Printhead(s) problem. The Following printhead(s) has a problem. black/yellow (K/Y)" I do not...
hi!!
try to re-install the driver of your printer
and then try to unhook the cartridge and then
clean up the nozzle used alcohol and cotton buds
and then placed it back the cartridge correctly!!!
Nov 10, 2008 | Office Equipment & Supplies
Simple solution is:
Oct 31, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Paper jam Brother MFC-215C
Norman,
does the printhead run smoothly to the left side of the printer when it is powered on?
If the printhead cant run that freely, it will give you the paperjam message. You have to dismantle the printer again, connect the scanner and cables again when top cover is removed. Press the scanner open contact (opposite to the menu button) and watch the printhead run to the left side. It might be that either the printhead stucks somewhere on its way (press the cover of the printhead. It might be the reason) or the guide rail hinders the printhead to move.
Oct 13, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP Officejet Pro L7590 All-in-One InkJet Printer Logo
26 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
