Question about Kodak EASYSHARE 5100 All-In-One Printer
Can I re-size photos and get 4 on one A4 page? If
Can I re-size photos and get 4 on one A4 page? If so, how please?
I need to pull an 11" x 48" sheet through my printer
That will never work as the printer looks for pages that are standard sizes. If it comes across something that is larger, the printer reports a paper jam. Making banners is best done on dot matrix printers using listing paper. Otherwise on a home printer, you use the banner setting in your creation software, MS Word, MS Publisher, and you print as separate pages and stick them together or stick them on a backing sheet.
Oct 22, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
What kind of photo paper do I use with this printer?
Any photo paper will work up to A4 size. It depends on the size of photo's you'd like to print. If you want 4 by 6 prints, any 4 by 6 paper will work, just remember to put it on the "Photo Paper" setting. Hope this helps, please rate! =]
Mar 04, 2011 | HP PSC 1210 All-In-One InkJet Printer
When Im using my printer only 1/4 of page [prints,I need to have entire page printed,of photo 8.5x11
check your printer setting in your computer click the start button and go to printer and faxes click there and go to your default printer right click their and chose printing preferences then go on features you can set printing option A4 size
Oct 17, 2010 | Office Equipment & Supplies
How can i put 4 photos on A4 page-using an epson rx700
Go to your printers and faxes (xp), or Devices and printers (Win7) folder
Right click on the RX700 and choose Printer Preferences
Select A4 as the paper size
Select Page Layout tab and select Multi-Page and select 4 (default is 2)
Select 4 copies
Print away!
Alternatively, if you're using Windows, use the Office Picture manger, Picture and fax viewer of the like, and select the multi pictures setting. If you're printing one photo 4 times, remember to select 4 copies, as you're telling the app to print ONE pic in a 1/4 of the A4 page. You need 4 copies to fill the page with the same photo.
Hope this helps.
Aug 03, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    Have i320 - when I try to print from windows gallery I cannot change the paper size from 4 x 6 which seems to be the deault setting although I changed that to A4! My other printers do not do this
    go in control panel and than go on printers now click on properties and u must select there a4 size in page setup or page size.thanx and enjoy give me a comment on my sollutions
    Apr 30, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
    The page prints to a small version in top left hand corner. everything is set to A4. Have tried all settings Have tried paper feed from back and front. Unable to get it to print a full size A4 page even...
    Make sure on the Page Setup tab that the Page Layout says 'Normal-size' and not 'Poster' (poster tries to place four documents on a single printed sheet). If this is not the problem, try uninstalling and reinstalling the printer driver.
    Feb 10, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
    Only printing 1/4 of page
    Follow steps below
    Load photo paper or plain paper with the print side facing you.
    Open the All-In-One Center.
    Click the Saved images tab.
    From the Creative Tasks section, select Print an album page with various photo sizes.
    Click Change the category of layouts listed above.
    From the Selected Layouts box, select for example Only Borderless.
    Click OK.
    Select a paper size for the photos <- use DIN/4 to print on whole page
    From the Page Layout area, select a page layout.
    Drag the photos onto the page.
    Click Printer Settings.
    Select the paper size and paper type. <- use DIN/4 to print on whole page
    From the Quality menu, select Photo, and click OK.
    Click Print Now.
    Hope this is helpfull and answers your question.
    Aug 31, 2009 | Lexmark X2350 All-In-One InkJet Printer
    Card making
    This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
    Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
    Kodak EASYSHARE 5100 All-In-One Printer Logo
    16 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
