Question about Clark Forklift Horn Button Switch , Cat Etc
Clark fork lift will not move when shifed into gear model cmp 15L
  • Bruce Hathcock May 11, 2010
    Is the fluid level full? has the lever been adusted?
I have a clark dpm20n forklift that wont go forward or backwards. Can anyone give any advice? Thanks
clark forklifts have a safety device on the brake pedal hydraulics that prevents movement when lifting the forks
check the operation of that safety device as it may be jammed in the neutral position
Mar 14, 2016 | Clark Electrical Supplies
Clark forklift transmission
too much oil will cause froth of the oil and that will expand out of the breather
it will cause excessive heat in the transmission oil
Oct 26, 2017 | Electrical Supplies
I am looking for an owners manual on an old clark forklift. I was wondering if you can help me
Frequently Asked Questions about Products Manufactured and Sold by the Clark Material Handling Company
Where can I get operator's manuals, parts and service literature, and parts for my Clark lift truck or other Clark Material Handling Company product?
Operator's manuals, parts and service literature, and genuine Clark service parts for your Clark lift truck are available from your Clark dealer. Please be prepared to provide the complete Clark serial number to your Clark dealer when ordering service literature and parts.
How can I locate my nearest Clark dealer?
For the Clark dealer nearest you, please go to our web site at
http://www.clarkmhc.com
and click on "The Dealers," and then click "Look-up Dealer " Then enter your zip code and hit "Find DLR." The Clark dealer servicing
your area will be displayed.
How old is my Clark lift truck or other Clark Material Handling Company product?
Date of shipment information is available by sending an e-mail request to webmaster@clarkmhc.com. Please provide the complete serial number of the Clark lift truck or other Clark Material Handling Company product.
Where can I find the Clark serial number on my Clark lift truck or other Clark Material Handling Company product?
The Clark serial number is stamped into the serial number plate, which is usually located in the operator's compartment. If the serial number plate is missing or illegible, you can find the serial number stamped into the frame. On a Clark lift truck, this will usually be beneath the step into the operator's compartment and may be either on the left or right side of the lift truck. Note:Rubbing the flat side of a piece of school chalk over the stamping may make the serial number more legible.
Can I still get an operator's, parts, or service manual for my old Clark lift truck or other Clark Material Handling Company product?
Photo copies of Clark operator's, parts, and service manuals are
available for many old Clark lift trucks and other Clark Material Handling Company products. Please send an e-mail request to
webmaster@clarkmhc.com for manual numbers and availability. Please provide the complete Clark serial number. Please know, however, that all Clark operator's, parts, and service manuals must be ordered from your Clark dealer
Sep 18, 2013 | Washing Machines
How far can the forks move from side to side?
the forks can generally move only 6-12 inches from side to side by using the 3rd lever. However, all modern trucks have forks that are easy to manually move. Just lift up the pin that is holding the fork in its groove, and put it in the groove where it will work best for what you're doing. don't forget to lock it again with the same pin
Jan 13, 2013 | Heavy Machinery
Wireing on a clark fork lift
I havent done of these for many a year but their is or was only a few wires for a forklift when i used to repair them ,both diesel and gas types so what exactly is the problem here that you need help with the wiring ?
Mar 07, 2012 | Welding Tools
Gear selector honda shadow
Sounds like a bent shift fork or two. Replacing the bad shift forks is major surgery and is NOT recommended for the inexperienced mechanic. Several special tools are needed. The top end and gearbox get totally torn down just to get to the shift forks. This is a very expensive repair, guessing $2100 or so at the dealers. Bummer. Contact a few dealers to cofirm my view of the problem and the probable repair cost. The shift forks move left and right as the shift drum is rotated when you lift or push down on the shift pedal.
Jul 18, 2010 | 2000 Honda VT 750 CD Shadow A.C.E. Deluxe
Forklift hydraulic connections on the mast.
So if you have three cylinders then the extend ports of the cylinders(bottom) should go to the 'A side of the valve and the Rod end or retract (top) should go to the "b" side. The A or B are probably not marked. Each cylinder should go to the valve at the coresponding lever.
Apr 08, 2009 | Clark Forklift Horn Button Switch , Cat...
Clark Forklift Horn Button Switch  , Cat Etc Logo
620 people viewed this question
Top Clark Electrical Supplies Experts
Wayne Fellows
Wayne Fellows
Bill Boyd
Are you a Clark Electrical Supply Expert? Answer questions, earn points and help others
