Question about Maytag Dryers
I have an Admiral electric dryer that just quit working. It has power to the dryer but nothing is working...not even the light. Any idea?
  • 1 more comment
  • Randy Martin
    Randy Martin Sep 29, 2009
    Sorry. The model number is: LNC7764A71
  • Randy Martin
    Maytag model LNC7764A71
  • Randy Martin
    Randy Martin Sep 30, 2009
    Thanks for all the helpful information. It looks like I have a bad thermal fuse and I have ordered one. again, thank you.
  • 6,784 Answers
HI, check the following to address this issue.
1. No power to the dryer Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer or control board Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Posted on Sep 29, 2009
  • Maytag Master
  • 19,396 Answers
Check the thermal fuse located at the back of the dryer.
I can be more specific if model number as written on service tag is provided.
Admiral lnc7766a71 The dryer won't start, and the
Probably the drum belt is broken. Replace it, it's easy.
Oct 30, 2013 | Dryers
I have a bran new Admiral dyer that won't work
The dryer may have been wired incorrectly, e.g., 115v rather than 230v.
May 23, 2017 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
I have an admiral electric dryer. It stopped in the middle of a cycle and the light is out and it won't turn on. I checked the fuse box, the plug and the belt is still on, so what do I do now?
Did you test the power outlet with another device...Sometimes a power outlet will fail under the load of a high current appliance like a drier...If the drier runs on 220 volt current...and have circuit breakers instead of fuses...make sure the 220 volt breaker for the dryer is not tripped...If it is tripped...reset it....if not...have a tech to check the outlet. oncee it is established that the drier is getting power and still not working...you may want to get it checked out by service personnel....Hope this was helpful....PEACE.....
Jan 25, 2012 | Admiral Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
My dryer has quit running. Can't even turn it on.
Is this a gas or electric dryer.? Do you have an electrical testor. ? One that indicates voltage is best with 2 leads that can be inserted into the outlet. Couple of bucks at Home Depot.etc. If you have power in the outlet you have eliminated the house wiring as the culprit. Once you know then tracing for the problem can continue in the proper direction. If you are not savvy on electricity you may need trained help for this.
Jun 07, 2010 | Dryers
Will not turn on
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Dryers
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
Can't open Admiral ADE7005AYW
Try sliding a thin putty knife rearward at each front corner of the top while lifting upward slightly. Shine a light into the joint and look for metal joining the two halves. Once the top is loose, look for screws in the inside front edges and lift up on the front panel to release. Make sure to pull the power plug while working in there.
Oct 22, 2009 | Whirlpool LER5636P Electric Dryer
Dryer won't come on
and also change your cycling thermostat if your thermal fuse is bad chances are the thermostat is bad too
Mar 11, 2009 | Maytag Dryers
Maytag dryer quit working
check your braker turn off then back on
Dec 12, 2008 | Dryers
Dryers Logo
53 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
