Question about Canon PowerShot A95 Digital Camera
I am not geting a clear picture - Canon PowerShot A95 Digital Camera
Google make google my home page
Try clearing the cache to it.
Nov 24, 2013 | Computers & Internet
I'm geting purple picture a mixtures of good and bad
Hi it sounds like your sustain boards are going bad. The sustain boards are located on the left and right side of the tv. One or both might be defective.
You can get parts at www.interliquidparts.com
Dec 05, 2011 | Samsung SP-R4232 42 in. Plasma HDTV
Can take clear sharp pictures outside, but inside it stays dark . the only way to take movies inside is to put the camera on night shoot, why is there a difference, can I set the camera to the right thing...
If you messed with the sharpness and brightness setings (and saved the setings), the problem might be the sensor that senses the light on your camcoarder, or maibe the rooms you're in are just too dark. If it's not that then see if there are any sensor settings you can ajust. if there aren't then it's ether just geting old or the manufacturer decided on the wrong sensor or the wrong settings for the sensor on the camera.
Sep 06, 2011 | Sony Handycam CCD-TRV68 Camcorder
I am geting the code 32. I changed the filter and sanded the metal rod. How do I clear the code and get it working again
To remove the code... turn off all power for a few minutes and then turn the power back on...
heatman101
Mar 05, 2011 | Carrier Heating & Cooling
Wat shd do for geting ma phone memory free
copy all the images,videos to your pc
Mar 13, 2010 | Nokia N97 Cell Phone
I have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
Feb 15, 2010 | Panasonic CT-36D32 36" TV
Saving mutiple pictures
Is there enough memory left on the phone to store pictures? Most phones have a pretty small memory availability without a memory card. If this is not the case, check the options when you turn on the camera function. There may be a setting in there that needs toggled.
Jan 01, 2009 | Pantech Matrix Cell Phone
Trying to print 4by6 pictures I am only geting about 2/3 of the picture
when you give the print command then u are not set the aproprite paper and picture size if you contact me then i will give the online solution
Aug 02, 2008 | Office Equipment & Supplies
No sound or picture HL-R5067w
sounds like ur tuner is bad.. ur better off buying a new tv then geting it repaired
Jan 18, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Canon PowerShot A95 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
