GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Problem for GE 24 in. Profile PDW9880JSS Built-in Dishwasher
The water wont drain out the bottom ...i cleaned
By alan_beinhac on Sep 29, 2009
the water wont drain out the bottom ...i cleaned all the screens inside
Solution #1
posted on Sep 29, 2009
Not Rated)
localwonder
Rank: Guru  GE Expert
Rating: 92%, 2809 votes
HI. check the following areas for faults.
1. Air gap / Drain hoses If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the Motor If defective.
6. Timer Replace if defective (note: uncommon problem).
Comments:
Sep 29, 2009
- The drain valve is typically near the motor although it can be located elsewhere. Look for a water hose running from the motor or underside of the tub. The hose should lead to the drain valve. The valve consists of the the gate arm mechanism and a solenoid (also called a coil). The gate arm allows the water to flow out of the dishwasher's tub through the drain valve. You should be able to move the gate arm up and down easily and smoothly. The gate arm also has two springs attached to it. If either of the springs is missing or damaged, they should be replaced.
The gate arm mechanism is engaged by the drain valve solenoid. The solenoid is connected by two wires. Label the wire placement on the solenoid before disconnecting the wires. The wires are connected with slip on connectors. Firmly pull the connector off of the solenoid's terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Test the solenoid for resistance using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to roughly 40 ohms when the probes touch the terminals. If the reading is infinity or substantially different from 40 ohms, the solenoid should be replaced asap.
Was this helpful?
Yes
No
Popular Solutions for GE 24 in. Profile PDW9880JSS
Questions and Unsolved Problems for GE 24 in. Profile PDW9880JSS
Do you recommend GE 24 in. Profile PDW9880JSS Built-in Dishwasher?
Answer
Answer
our power temporarily went out and when it came back on the beeping on the dishwasher would not... (More)
Answer
The smart soap dispenser on my GE profile dishwasher is not dispensing soap. I filled the smart... (More)
Answer
my hotpoint bf162 door will not close but dishwasher believes its closed so if you switch it on... (More)
Answer
Smart dispense is not working. I don't know if I mixed kinds of detergents or not. Is there a easy... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE 24 in. Profile PDW9880JSS...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
