Question about Honeywell HE360A1027 Whole House Humidifier Humidifier
Wiring problem We are having a similiar problem-- wiring from HUM terminal on furnace to mechanical humidistat to humidifier to common terminal on furnace. Seems right. Everything worked at first, then the solenoid smoked a little and the humidifier stopped. Any insight?
  • 61 Answers
Sounds like you may have put 120v through a 24v solenoid and humidistat.
Is the HUM terminal on the furnace 120v or 24v?
If it is a 120v terminal you will need a 120x24v transformer and a new solenoid and maybe a new humidistat.
Posted on Jan 02, 2009
Wire Honeywell HE220 to N8MPN/L, *8MPN/L furnace control board
HI
I have similar isssue with HE220 but in my case the water run through all ththe time, even when unplugged from the power outlet.
Would that be solenoid issue?
the unit run fine for last season so the wiring is fine.
Any ideas would be greatly appreciated.
Jan 22, 2012 | Honeywell HE220A1019 Whole House...
I was told by the technician tha insalled my funace that I could wire te humidistat to it bu I cant remember what teminals to use the terminals are lettered G W R Y C the thermostat uses W R Which one...
None of these.
Coming off the humidifier you wil find 2-red and 2-yellow (through a plug).
The red supplies 24 volts and is wired to the "hot" and "common" terrminals of an electronic humidstat. (They are NOT used if using a mechanical humidstat.)
The 2-yellow are wired to the "HUM" terminals of the humidstat (either mechanical or electronic).
If you are using a sail switch or current sensing relay, it cuts into one of the yellow wires. (Yellow from humidifier to to humidstat. Then from other terminal of humidistat yellow runs to to relay (or sail switch). Then from other terminal of relay (or sail switch) yellow back to humidifier.
Dec 14, 2010 | Honeywell HE360A1027 Whole House...
Humidifier will not turn on (no fan, no water flow)
http://www.appliancefactoryparts.com/humidifiers/helpcenter/breakdowns/honeywell/honeywell-he360a1027.html
A breakdown diagram of parts etc above.
http://www.appliancefactoryparts.com/content/pdfs/110672-4.pdf
Shows you the HE360A.
To me it sounds like it is wired incorrectly, the solenoid should NOT get too hot at all. The PDF above shows wiring data.
Apr 03, 2010 | Honeywell HE360A1027 Whole House...
Do I need a transformer if my furnace has HUM port
Yes you still need a transformer the hum. port on the furnace goes to the 24 volt transformer. one leg of the primary side goes to the transformer and the other leg of the primary goes to the neutral on the board. Then you have your 24 volt terminals one goes directly to the humidifier and the other goes to the humidistat the other wire from the humidifier goes to the humidistat.
Jan 25, 2010 | Honeywell HE260A1010 Whole House...
Function of HUM terminal on 1Source Panel
That will work, The HUM feeds power to the humidifier when the fan is operating even in cooling on most models, However the humidistat must also be calling for humidity and probally won't call during the cooling months
Jan 15, 2010 | Aprilaire 700 Humidifier
Wiring issue with the Honeywell HE360A Humidifier
Maybe I can help. this is 24v so it doestn't matter which wire goes where so here goes. 2 wires from humidistat go to furnace, split one of the wires(not both) so they reach the yellow wires on the humidifier. with marettsconnect one of the split wires to one of the yellow wires. do the same to the other split wire and yellow wire. what you should get is one wire from humidistat to furnace then one wire from humidifier to humidistat and one from humidifier to furnace. hope this helps
Jan 31, 2009 | Honeywell HE360A1027 Whole House...
HE220A direct wiring to protech 62-24084 control board
it is best to use a seperate transformer for the hummidifier, but in some cases you can use the low voltage t-stat wire that runs your furnace, you will need to have one wire run to common, and the other to the heating side of your low voltage, normally its the red wire hooked to the w circuit of your terminal board, if you do decide to go with an extra transformer, make sure you you have it wired to bring on the humidifier only when the unit calls for heat, hope that helps
Jan 19, 2009 | Honeywell HE260A1010 Whole House...
I have a Honeywell H220a humidistat and have everything hooked up, but I cannot get the wiring to work. The wiring diagrams do not include the selanoid that comes with the humidistat. Any suggestions. The...
Thanks for your question Mike,
The wiring for your humidistat and solenoid are fairly simple, you will need 24volt t-stat wire, you have the two wires at the Solenoid, one wire goes to the terminal board at the furnace, it connects to the (c) or common terminal, the other wire connects to one leg of the humidistat, run another wire from the other leg of the humidistat, to either the HUM terminal on your furnace circuit board, make sure its not a 120v leg, should say in the owners manual, if if is or your not sure, connect that same leg to the (w) terminal at the furnace, this way it only comes on in heating mode, some models need a second 120v-24v transformer, but you would still wire it through the same way, only exception is that you have to hook up 120v to the transformer, and route your wiring like I told you above but through the transformer to complete the circuit, hope that helped you out Mike, please let us know, thanks again, mr.grzz
Jan 10, 2009 | Honeywell HE220A1019 Whole House...
Installation problem
I WOULD CHECK TO SEE IF YOU HAVE ENOUGH V/A OUT-PUT ON TRANSFORMER. I DONT KNOW IF YOURS CAME WITH ITS OWN TRANSFORMER. IF IT DIDNT YOU SHOULD HAVE A MINIMUM OF A 40 V/A RATING STAMPED OR PRINTED ON THE EXISTING TRANSFORMER. IF THE TRANSFORMER IS EXTREAMLY HOT ... YOU MAY NEED A 75 V/A TRANSFORMER WITH THE SAME VOLTAGES. INCREASING THE V/A CANNOT DAMMAGE ANYTHING IT JUST GIVES YOU MORE POWER WHEN EXCESIVE CONTROLS AND WIRING ARE ADDED TO A HVAC LOW-VOLAGE (24v) CIRCUIT. IF YOU LIKE YOU CAN CALL ME AT 727-363-7071. I AM A RETIRED HVAC&R CONTRACTOR WITH 45 YEARS EXPERIENCE. I HATE THE NEW SENSORS THEY HAVE TO ACTIVATE THESE NEW HUMIDIFIERS. I USE TO WIRE THE HUMIDIFIER TRANSFORMER (SUPPLIED WITH HUMIDIFIER) TO THE LINE (110V) SIDE TO THE LOW SPEED ON YOUR BLOWER MOTOR. THAT WAY THE ONLY THING THAT INTERUPTS THE CICUIT IS THE HUMIDISTAT. YOU NEVER WANT THE HUMIDIFIER TO RUN IF YOUR SYSTEM IS NOT "CALLING FOR HEAT". NEVER TRY TO ENERGIZE THE WATER SOLENOID THROUGH YOUR HEAT WIRE(USUALLY SMALL THE WHITE WIRE) FROM THE THERMOSTAT. THIS WILL RESULT IN BURNING YOUR HEAT ANTICIPATOR OUT ON THE T-STAT.
Jan 28, 2007 | Honeywell HE360A1027 Whole House...
Honeywell HE360A1027 Whole House Humidifier Humidifier Logo
756 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
