Question about Electric Chainsaw Sharpener
Have an HT101 pole saw, nearly new condition, that just would not start after running quite smoothly. Stihl dealer took apart & found a broken piston ring; about 1/8 of ring end missing but with no trace of the missing part and no damage to the sleeve or piston. Bought new rings & reassembled per their guidance relative to crankshaft to cam gear alignment. Saw still will not start. Check of spark plug indicates spark is strong. Removal of exhaust and cranking shows gas fumes exhausting ok and an occasional 'pop' indicating combustion but not sustained. Talking with a Stihl rep, he indicated that the coil, if the ID number is below 515, which it is, may be problematic. Any sugggestions as to further checks. It still seems that either the spark timing is off, meaning that reassembly was done incorrectly or the coil is defective. Thanks; John at johnbethbrausch@aol.com
  • bczerkie May 11, 2010
    Is it still down? 2 months but no update. In reply to new coil not bad, new stuff does go bad all the time. My HT 101 coil died on first job, was replaced and now is fine. Did you see the broke ring. are you saying 1/8 ring gone or 1/8" of ring gone? You will have a gap, called ring end clearance. shape of ehd should tell if broken or not and gap. Did tech. set coil gap or did you? Let me know where you are on repair. and all work should be free for that as has great warrenty on electronics. Bill Czerkie
  • 157 Answers
Its not likly to be the coil on a relativly new machine it sounds as though the technigtion put something together wrong
Posted on Sep 29, 2009
Stihl ht101 pole saw
The unit was not as advertised. Hard to start, runs poorly and won't idle. Had to take it to the local stihl dealership for service.
For best pole saw open the link The Best Pole Saw In 2018 Practical Overview of Top Pole Saws
Mar 20, 2017 | Stihl Garden
STIHL pole saw 101
Hi Little Bird
Chances are that the clutch needs servicing or replacement.
Here's a link that explains:
http://www.lilredbarn.net/Stihl-HT-101-Pole-Pruner-Clutch-s/29554.htm
Cheers
Jun 06, 2016 | Stihl HT101 Pole pruner
Motor runs but everything above motor does not work. how do I take pole from motor?
Either the drive shaft has broken or come detached from the clutch drum at the motor end or the attachment end.
Here is the breakdown diagram http://www.mediafire.com/view/a33fr2038d5u1cr
Oct 16, 2015 | Stihl HT101 Pole pruner
Stihl ht 101 spare parts list pdf
Stihl does not supply parts lists to the public. if you want one you will have to talk to a dealer in your area and see if they will be willing to allow you to look at one
Jan 20, 2014 | Stihl HT101 Pole pruner
Stihl pole saw trimmer is not pulling gas into the cylinder from the carburetor
could be a carb issue, a split in a fuel line, damaged intake boot or gasket
Nov 10, 2013 | Stihl HT101 Pole pruner
I CAN'T REMOVE THE SPLINED SHAFT FROM MY STIHL HT101 POLE PRUNER.
Take it to an authorized repair center. Not what you want to hear but its better that way. It is a complicated ordeal that if you aren't trained for you can do damage to the shafts
Nov 01, 2012 | Stihl HT101 Pole pruner
I have a stihl pole saw ht101. The saw starts fine and runs for a minute or two, then loses power. What ido I check?
If you mean the engine is losing power your more than likely have a restriction in the exhaust. The sut from the two stroke mix builds up and restricts the exhaust gases. Hence looses power. Happened to me lots of times
Aug 02, 2012 | Garden
Electric Chainsaw Sharpener Logo
634 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
