Question about Traulsen 24.2 cu. ft. / 685 liter Commercial Freezer G12010
The freezer is not holding a cold enough temperature. I put warm drinks inside and the temp will rise to 40-45 degrees and not cool back down. The drinks can sit inside for 4-5 hours and still be warm. I
2 Suggested Answers
danlecours
  • 61 Answers
SOURCE: my traulsen refrigerator is warm not cold
the pump unit is burn
or you have a leakage on the cooling fluid !!
all your dealer and ask the sometime the answer those question with no charge $$ !
Posted on Apr 05, 2015
What does the temp display on the freezer tell me?
unless this is a dedicated freezer only and not a side by side or over/under , there's no way it's going to get down too 0 degrees inside a warm home , nope not gonna happen
also its not good for you to set this there as compressor wont cycle properly there and entire freezer will ice up , then believe it or not it will get warmer not colder wastes a lot of power as well
Sep 10, 2015 | Freezers
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Wont turn off
This mentions ref/freezers but goes for both side by sides and just freezers alone:
This can be a tricky problem. There are three things that I can think of that can cause this. First is the defrost timer. To determine if this is the case look in the freezer at the freezer back wall. Is it cover completly with snow like ice? If so the timer is not letting the machine go into defrost. Also you should notice the fresh food part of the machine start to rise in temperature. The next thing is the machines cold control thermostat is faulty and even though the machine maybe cold enough the thermostat can't tell so it never kills power to the compressor. The last is that your machine is low on freon, so the freezer temperature never really gets low enough. Signs of this are decrease in ice maker production, ice cream softer than normal, or put a thermometer in t he freezer. The temperature should be around 0 degrees F and no more that 5 degrees F
Jun 22, 2012 | Electrolux Freezers
Frost on the evaporator
watch this video I made. this is subzero with low level of freon (almost out). same situation on all refrigerators and freezers. you can see ice at the begging of evaporator. if there would be a little more freon evaporator might of frost up at the top might frost half of evap other half would be not even cold.
Jan 28, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Red light is on on bottom panel and buzzer is going off. Inside temp is 20 degrees and outside temp is 25 deg
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Not all refrigerators are insulated the same and not all condensers are in the same place. Your cold control is monitoring the temperature of the refrigerator section and is designed to turn off the compressor to keep things from freezing in that section. If it stays cold long enough outside in your garage the cold control thinks its cold enough and won't turn the compressor on. A makeshift closet to hold a little heat the unit generates will probably help.
Jan 06, 2010 | Freezers
Temp changes in freezer
If the temperature fluctuations occur (at least the ones to 20-30 degrees) at intervals of 6 hours or so then you are catching it in it's defrost mode which occurs on a timer. The timer shuts off everything except lights every 6 hours for an average of 20 minutes. This usually isn't enough to thaw things but I have seen it cause some crystale. Look closely at the back inside wall of the freezer for an accumulation of frost. If you see it there then you may have a defrost problem. Usually this is accompanied by steadily rising temperature in the freezer and fresh food secions both. The temps you listed (0to10) are fine. Good luck, AJ
May 22, 2009 | Freezers
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Freezer and fridge stop working when home temp is cold
ketner1 what you are looking for is an old style freezer. They ran so hot that they didn't care what the temps in the garage was. Here is a suggestion. I am not sure what kind of freezer you have had, but look for one that doesn't have a coil on the back of it. Freezers with the condenser in the cabinet work well at the temps you are looking for, however they don't work well in garages at 90 degrees, then they just transfere the heat to the inside of the freezer. This is the style my parents use and theirs is in a storage shed with no heat.
Feb 02, 2008 | Freezers
Master-Bilt Freezer doesnt cool enough
The only thing I could suggest is looking at the evaporator (inside coil / cold bit) and making sure it is not frozen over reducing the airflow through the coil. If it is then put it onto a couple of defrost cycles to clear the ice build up. Not sure exactly of this type but would assume you also have a sight glass on the external unit, you can check this to see if when running the sight glass is clear (fully charged). Another check is looking at the compressor and the larger of the two lines (suction) should be cold back to the compressor (this line is normally insulated). However I would suggest your best course of action is a good refrig. techy. Hope this helps.
Sep 03, 2007 | Freezers
Traulsen 24.2 cu. ft. / 685 liter Commercial Freezer G12010 Logo
Top Traulsen Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
