Question about Garmin nuvi 255W GPS Receiver
Charging my nuvi 250 with a USB cable from my apple
My cigarette lighter in the car has broken so I now have my nuvi connected to my Apple via USB. It switched on immediately I connected it and has an image of it being hooked up to a hard disk on the screen and says GARMIN, however that's all it does. Is it charging in this state? Thanks.
  • 35 Answers
When the GPS is hooked up to charge the battery it will say charging,try turning it on when hooked up and see if it is in fact charging,otherwise have you thought of purchasing a wall charger,I got mine on Ebay,very reasonable and works great,saves the hassle of hooking up to my comuter.Hope this helps with the problem.
Posted on Sep 29, 2009
Testimonial: "Thanks for that,it did charge but you're right I think a wall charger would be a good idea."
How do I recharge the battery on my Garmin Nuvi 255WT? I would also like to know how to update my Garmin?
Recharging the battery is done by connecting the nuvi to a vehicle power cable in the car through the vehicle power accessory outlet or cigarette lighter.
The unit can also be charged via a powered USB port off your computer via the USB power/data cable or an AC power adapter through the USB power/data cable.
Aug 15, 2011 | Garmin nuvi 255W GPS Receiver
I dont know how to charge my GARMIN nuvi 1200 with the usb cable
There are 3 ways to charge your garmin nuvi 1200 as follows;
  1. Connect your satnav to a computer with the mini USB cable. Plug the narrow end into the satnav, where the power cable goes, and the other end into the USB port of your computer. Both computer and satnav must be turned on. It will take about 8 hours to charge like this.
  2. Connect your satnav to your car charger and plug the charger into the cigarette lighter socket of your car. It will take about 4 hours to charge.
  3. You can get an optional mains charger which also takes 4 hours to charge the satnav.
May 23, 2011 | GPS
Battery
The unit will take a very slow charge via your computer. I tell most people no it doesnt charge VIA your PC just because it takes soooo long. I recommend getting a new power cable from GPSCity. Just call them up or follow the like to the cable you need.
** This cable is for the Nuvi 200 series GPS units
http://www.gpscity.ca/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi-in-web-packaging.html
Cheers
Jul 13, 2010 | Garmin nuvi 260W GPS Receiver
Hi i have garmin nuvi 205w i was showing me ,accessory not suppor
maybe it is not charging
does the charging light come on?
both on the unit and on the car power plug.
does your cigarette lighter in the car power other things?
you can charge it with a mini-b usb cable connected to a computer.
Jan 14, 2010 | Garmin nuvi 750 GPS Receiver
The cradle no longer charges the garmin in my vehicle. It's not charging anymore. Nuvi 750
Sometimes, if the Garmin GPS battery is allowed to fully discharge, it would require charging directly via USB cable connected to a PC or Mac before it would accept a charge for the cigarette lighter again. Try connecting this way for 4 - 8 hours or more before going forward.
Check the cigarette lighter plug in another "known good" lighter socket / vehicle to help rule out a defective socket. A socket without power indicates anything from needing to change a "simple to replace" fuse - or a bigger problem - damaged wiring in the vehicle (if the socket is used to light cigars & cigarettes - vacuum the socket out to remove ash and tobacco that may collect inside). Trying the GPS elsewhere helps eliminate possible problems with the socket. If it doesn't work elsewhere, depending on the plug that goes into the socket, it too may have a built-in fuse. Check the plug for an exposed fuse - or see if the tip unscrews to provide access to a fuse inside. If unsure, the tech Support people at Garmin are a great source for free help.
Lastly, dirt or grime on the "cradle to GPS" connection or "cable to cradle" connection could be causing the failed connection. In short - carefully inspect all points of connection and remove any deposits found.
Sep 16, 2009 | Garmin GPS
Charging the battery in Nuvi 760
1) Check the cigarette lighter is working by plugging in the lighter unit and see if it gets hot. If it doesn't then it is possible the fuse has blown.
2) You can plug the unit into a PC using the USB cable and if there is a fault you will get a message on the screen about 'USB over-current' but it shouldn't damage the computer.
If it runs/charges using the PC and (1) is OK then you may have a problem with the cigarette lighter - cradle cable or a problem with the cradle itself.
HTH
Peter
Jan 24, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Nuvi 350 wont charge with car adaptor. But charges with ac charger in usb port of Nuvi. Any thoughts? I have another Nuvi 350 that does charge with this ones car adaptor.
Are you using the same port on the Nuvi to connect the car adapter and the ac charger, or two different ones? If not, then the jack could be broken (solder joint, pin?).
Aug 10, 2008 | Garmin Nuvi 350 Car GPS Receiver
Don't work with the cigarette lighter connector
Check if you are able to charge other devices via the cigarette lighter such as a cellphone or try to use the lighter if the light does not get as hot as normal then that means that there is not enough power. If that looks ok then try another cable charger for your Nuvi
Aug 09, 2008 | Garmin 010-00358-00 GPS Receiver
Can I find a copy of the Garmin Nuvi 350T manual online please?
Yes. There are 3 ways to charge the Nuvi. Computer USB cable, 120VAC transformer wall plugin, and the cigarette lighter DC 12V plug for your car.
May 24, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
165 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
