Kenmore dryer model 86375100 63751 how far can this dryer be vented
    Sergeant:
  • 363 Answers
You should post to appropriate category, i.e. Dryers, but usually a longer distance to exhaust is less than ideal. You should probably not raise the exhaust above the top of the machine either. Repost in Dryers for better reply :)
Joe
Posted on Oct 01, 2009
My kenmore series 80 model # 110.74852400, takes forever to dry. the flame comes on, but doesn't seem to stay on for long. please help. thank you
my kenmore dryer ignites runs for awhile then wont reheat. let it sit for a few minutes and it will heat again for awhile
Apr 20, 2010 | Kenmore 72802 Gas Dryer
Kenmore 110 60942990 dryer works but takes 3 hours to dry a load.
Venting. When elements or thermostats burn out it is almost always caused by venting restrictions. Vent is plugged with lint, smashed(usually from the dryer being pushed back to far) vent run is too long, or nylon stocking on vent outlet. Also check to see if you can pour water through your lint screen. Sometimes fabric softener builds up on the screen and restricts the air flow. Scrub your lint screen to get this build up off. Good Luck, Appliance Specialists
Dec 16, 2009 | Kenmore 62802 Electric Dryer
No heat from dryer model kenmore 11062702102
Make sure that your vent is clean of lent. If your vent clean, then it is your element.
Nov 24, 2009 | Kenmore Dryers
Kenmore Dryer 110.64632300 won't heat up!
vent pipe kinked not letting heat away from dryer, check vent , or the thermostt stuck and not cycling heating element cycle off
Aug 12, 2009 | Kenmore 63942 Dryer
Dryer is hot, clothes arnt getting dry. blower? less that 1 year old Kenmore
Remove the vent hose from the dryer and dry a load of clothes . If they dry , then dryer is pushed too far back , kinking vent hose , or the vent from the dryer to the outside is blocked somewhere . A dryer either heats or doesn't heat (except for maytag associated dryers ) in which the blower wheel could be stripped out . But Kenmores don't have blower problems .
Aug 09, 2009 | Kenmore 600 7965 Dryer
MY DRYER GETS HOT ON TOP OF THE DRYER (KENMORE) COULD IT BE THE VENT?
start dryer, go outside and see if vent is blowing hot air. If not then vent is clogged with lint, esp if vent has a curve or elbow in it. unhook vent at dryer or os vent and run a vacumn hose in as far as you can. easy way to determine if vent is to unhook at dryer and see if dryer blows air, could be just inside at vent opening
Jul 11, 2009 | Kenmore Dryers
Kenmore Dryer not drying
First you will need to chekc the exuagst venting and that noone has pushed the dryer too far back kinking the vent. If its not heating whatsoever You may need to check the internal fuses which may be located using the mini manual located in the dryer control panel.
Mar 29, 2009 | Dryers
Vent line from unit to outlet is 30' away. Will dryer push air and lint dust that far or do I need a inline vent-fan?
it will push that far but you must not use flex pipe that far across run a solid pipe across to dryer then put flex pipe stright dryer to vent
Feb 20, 2009 | Kenmore Dryers
Dryer to hot and smoking
Get a dryer vent cleaner and stick it in as far as it will go. You have a plug somehwere in the vent and it needs to be cleared, try doing this from the top down to avoid making the clog worse
Feb 08, 2009 | Kenmore 82722 Electric Portable Dryer
Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Jan 09, 2009 | Kenmore 62802 Electric Dryer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
