Printer will not print - Office Equipment & Supplies
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
Print colour pictures from laptop to printer
If your printer can print in color and your printer is set to print in color, then you need to do nothing else, it should print in color. There are only 4 things that could prevent you from printing in color. 1. The printer settings is set to print in shades of grey. 2. The printer itself is set to print in black and white only. 3. There is no more ik in your color cartridges. 4. You don't own a color printer.
Sep 30, 2014 | Toshiba Computers & Internet
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
Power went off when I tried to print
Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
Printer Does Not Start or Stops During Print Jobs
Inner Cover was open when you started printing.
Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
Inner Cover was opened while printing is in progress.
A page of print data being sent at the time of the error will be erased, so print that page again.
The printer has been printing continuously over a long period.
If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
i_expl.gif Caution
The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
Out of paper.
Make sure that paper is loaded in the selected paper source.
Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
If both paper sources have run out of paper, confirm the selected paper source and load paper there.
Printing documents with plenty of photographs or illustrations.
When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
i_note.gif Note
If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
My printer refuses to print. The Red Status light came on so I checked and found there was a paper jam - cleared that. Can get green light to come on if I press the job cancel button but still cannot get...
Perform a Factory Reset
Turn the printer power switch OFF on the right side of the printer. Check that the front cover is closed.
Turn the printer power switch ON while holding down the GO button until the Toner, Drum, and Paper LEDs are lit.
Release the GO button. All LEDs will be off.
Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the Ready LED will be lit.
Print a Test Print Page
Print the Print Settings by pressing the GO button three times.
- If the Print Settings pages do not print, check for alarm lights on the printer. Clear the printer error before trying to print again.
- If the Print Settings pages print, the problem is isolated to printing from your computer. Verify the printer cable connects from the back of the computer directly to the printer. If the cable has become disconnected, loose, or connects through another device, the printer may not be able to print.
Check the Printer Driver Properties
Follow the instructions below based on the operating system installed on your computer.
Windows 7:
Click on the Windows icon => Control Panel => View Devices and Printers.
Right mouse click the Brother printer. Left click See What's Printing. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
Click Properties from this Printer menu list.
Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
Click the General tab and Print Test Page button. The Windows test page should now print.
- If the Windows test page prints, try printing from a program.
Windows Vista:
Click on the Windows icon => Control Panel => Printers or under Hardware and Sound click Printer.
Right mouse click the Brother printer. Select Run as administrator and left click Open. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Windows XP and 2000:
1. For Windows XP Professional, click on Start => Printers and Faxes.
For Windows XP Home Edition, click on Start => Control Panel =>Printers and other hardware => Printer and Faxes.
For Windows 2000, click Start => Settings => Printers.
2. Double-click the Brother printer to open the print queue. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
3. Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
4. Click Properties from this Printer menu list.
5. Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
6. Click the General tab and Print Test Page button. The Windows test page should now print.
Nov 01, 2010 | Brother HL-5240 Laser Printer
My printer want print pdf files
hi...
while you print please check weather you selected the printer in which you need to print.
to select it
Go to 'printing option'------>'properties',there is a drop down arrow to select the printer please select the correct printer and try printing
thanx
Jul 17, 2010 | Lexmark Z1300 InkJet Photo Printer
Printer problem
The HP DeskJet printer will not print, it prints only partial pages, or produces ... remove the scanner, remove the printer driver, and reinstall the printer driver with all programs and ... the paper out of the printer after printing is finished. If one, or ... the kicker feet on your printer are broken, have the printer serviced. ... In tray only when the printer is not printing. Adding paper while printing can cause paper jams. Do ...
Jan 17, 2009 | Office Equipment & Supplies
HP C4200 Printing both sides
Some printers automatically print on both sides of a page (automatic duplex printing); other printers allow you to manually reinsert pages to print the second side (manual duplex printing); and some printers do not support duplex printing at all. To find out whether your printer supports duplex printing, you can check the printer manual, contact the printer manufacturer, or check the printer's properties by clicking Properties in the Print dialog box.
To find out whether your printer supports duplex printingThe options in the Print dialog box can vary depending on your printer options and configuration.
You can use the following clues to determine whether a specific printer supports duplex printing:
  • Check your printer manual or consult your printer manufacturer.
  • Click the tabs in the Print dialog box and review the options. If options such as print on both sides of the paper, duplex printing, or two-sided printing appear on any of the tabs, the printer probably supports automatic duplex printing.
Notes
  • If you are printing to a combination copy machine and printer, and the copy machine supports two-sided copying, it probably supports automatic duplex printing.
  • If you have more than one printer installed, it's possible that one printer supports duplex printing and another printer does not.
To manually set up a printer to print to both sides of a sheet of paperWith some printers, you can use the Manual duplex check box under Printer in the Print dialog box. Word will print all of the pages that appear on one side of the paper and then prompt you to turn the stack over and feed the pages into the printer again.
You can also use the following procedure to set up your printer for manual duplex printing:
  1. On the File menu, click Print.
  2. In the lower-left corner of the Print dialog box, in the Print box, click Odd pages.
  3. Click OK.
  4. After the odd pages are printed, flip the stack of pages over, and then in the Print dialog box, click Even pages.
  5. Click OK.
Note Depending on the printer model, you might have to turn and reorder the pages to print the other side of the stack.
Sep 08, 2008 | Office Equipment & Supplies
12 people viewed this question
jasbo
jasbo
