Question about Bunn VPS Coffee Maker
Wall plug burned out. Coffee maker just stopped
Wall plug burned out. Coffee maker just stopped working
  • 124 Answers
Your unit will need service now.
Contact a Bunn service center
Posted on Jan 03, 2010
Electrolux coffee maker not using all the water, beeps 3 times and stops brewing. any suggestins?
I would guess you have already pulled the plug from the wall and done a reset of the machine and tried again?? if that doesnt work I would recommend returning to store you purchased it at for repair
Jun 10, 2016 | Electrolux Coffee Makers & Espresso...
Platinum keurig no power
under the warranty they mist give you a new one
Apr 10, 2012 | Keurig Platinum B70 Coffee Maker
How hot should fresh perked coffee be from any coffee maker?
some people say that coffee can burn when you pour boiling water on the beans and recommend that you should add the milk first... I just let the kettle cool down until the boiling stop as well. as for espresso makers, water will boil and the gas (liquid to gas at boiling temperature) is pushed through the beans, so its rather hot and the beans doesn't burn.coffee should be as hot as possible!
Apr 02, 2012 | Coffee Makers & Espresso Machines
There are 3 buttons to brew with and you get different amounts of coffee for each button. Lately the last button on the right gives the same amount of brewed coffee as the 1st button so if I want a full...
just plug it out from the wall current for about half day so that the coffee maker can reset itself then plug it in back.if that does not work that means the timing transistor is faulty.you will have to have it repaired.good luck.
Sep 25, 2011 | Keurig Special Edition B60 Coffee Maker
The two coffe option lights keep flashing back and forth and the machine will not start
plug out the power cord from the wall outlet then plug in back after 4 hrs probably it want to reset.if this does not work then you will have to get it repaired.the problem is the ic or the transistor that control the heating of the coffee maker.good luck.maybe you will need to invest in a new coffee maker.
Sep 25, 2011 | Nespresso Le Cube
Lite is on will not brew there is water and coffee and it doesnt brew
You can try this.
1. Plug the coffee maker into the wall power outlet. Turn the switch on. The light will glow. Then press the on/off switch TWICE. The coffee maker will start.
2. If the machine doesn
Aug 02, 2011 | DeLonghi DCM485 Coffee Maker
I have a black and decker ODC450 coffee maker where the display went blank and it will not work at all. Any ideas?
This could signify water damage so be careful!!
If the machine smells slightly like burning plastic, DON'T use it. take it in to your local electrician to have a look.
If you think its ok...
Check your house power, Change to another power point, check your house fuse box, if this is not the problem then DISCONNECT the coffee machine from the wall, take off the back cover or bottom and look for a fuse to replace.
Take care
Regards
Ian
Nov 03, 2010 | Black & Decker SpaceMaker ODC150 Coffee...
I just plugged the coffee maker back its not making coffee!
So folks to solve this problem I used the last resort....don't laugh, but I actually started to hit the machine very hard on the top and from the side and all of sudden it started to work. When in doubt hit it!
Oct 18, 2009 | Keurig Special Edition B60 Coffee Maker
Coffee not brewing
This machine depends on heat to move the water to the top. The heating element, or thermal fuse, or burned contacts are the usual suspects. The warmer under the coffee pot is not part of the coffee making process. It is repairable.
May 05, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Bunn VPS Coffee Maker Logo
66 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
