I have a 61inch mitsubishi rojection screenTV and was told not to view letterbox, but most of my chanels have gone to widescreen and I can only view them in Letterbox with a large strip of black at the top and bottom-I think I will get that burned into my screen. What can I do.I have Dishnetwork and they do not have an answer
  • 50 Answers
Bright areas burn. I expect dark areas will not cause any problem. I use a LCD projector in letterbox mode.
Posted on Sep 29, 2009
Testimonial: "Thank you very much. I will come back to your site again when I have any problem."
Why are the movies half screen?
Movies that are created for "Wide Screen" viewing show up in letterbox on your TV. If you go to a theatre you notice it is a big rectangle. To be able to fit all of the widescreen movie on a TV it has to make the height smaller.
Because many people want to see the "complete" Movie, the "Letterbox Format" came about. I do NOT know what the word "Letterbox" actually means, or how that term was chosen. To get the complete Rectangle into that Square, they discovered that they could shrink the entire rectangle to fit that square. Meaning, what used to take 2 inches on your screen, now may only take 1.75 inches. Now a problem arrose. When you shrink the WIDTH to fit your dinky Square of a TV, the HEIGHT also has to be shrunk along with it, or else you're stretching the image as if it was on silly-putty ("Compression"). When the image was shrunk to fit the TV Screen, they were left with a gap at the top and bottom of the screen. So they simply fill it in with "Black". I guess the only alternative was to leave it snowy.
Nov 13, 2014 | Televison & Video
Black bars on my you tube screen on windows 7
That is completely normal. Most Youtube Videos are posted in a 4:3 Letterbox Format. If it was filmed or uploaded in a 16:9 Widescreen format you would not see those bars. Try this HD Widescreen Format video link and let me know if the bars are gone: http://youtu.be/yZgcjOJnk0k
Owner of Woodland Park Computers
www.woodlandparkcomputers.com
Dec 08, 2013 | Computers & Internet
I am having trouble getting the screen size back to full size. We used the zoom but that makes the picture to big. My TV is a Auria EQ5588
Hi, The " Size " of a flat panel tv ( when not in zoom mode ) is actually controlled by your programming, if using an hdmi cable from an Hd/Blu-ray player-then whatever format the disc was recorded in is what you'll see ( widescreen/letterbox ) black bars at top & bottom of scrteen ) or full screen. Local over the air digital H.D. brodcast's from networks varie from full screen to letterbox-satellite and cable that are standard definition will almost always letterbox a screen for you. Using T.V.s tuner may alleviate most of the issues. Good luck and I hope this helped. Prodzilla
Apr 10, 2011 | Televison & Video
I purchased a DVD that states: Widescreen Format (Aspect Ratio 1.85.1) I'm unable to get 'widescreen/letterbox'. The movie shows up full screen or a 'stretched' view. All other movies I've...
On the DVD recorder remote: press function menu button: enter setup screen - scroll down to connection - TV aspect - select either 16:9 / 4:3 Letterbox / 4:3 Pan&scan. If you are using an older TV which is not a widescreen, set the aspect to '4:3 Letterbox'.
You should now be able to view your DVD movies from this machine through a 4:3 standard TV in letterbox format. (some DVDs do not allow pan&scan so letterbox or widescreen is recommended). Very rare that a DVD title is not compatible with 4:3 TVs. I assume your deck is set to output 16:9 aspect by default.
I find this is the cheapest and easiest solution and can save lots of dollars in service call-outs. You can always reset the unit back to shipping condition later if you need to, or in the rare case of digital channels disappearing from your tuner memory.
Jan 09, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Mitsubishi ws-65411 appears to be in letterbox at all times seems screen is shrinking only time you see full screen is in zoom format tv is 2002 model I think thanks in advance joe
This model is HD but requires a box and is only 4x3 in HD. That means you will see selected HD channels in letterbox and many others may be formatted that way by the box you are using.
Their later sets were also HD but had 4x3 AND 16x9 which is full screen in HD provided the box is sending it that way.
I do not think anything is wrong with your set--it is just the way it was intended to work.
IF this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 04, 2010 | Mitsubishi WS-65413 65" Rear Projection...
LG 37lH20 LCD Aspect Ratio Problems
Not ur tv it the dvd format,tries it with other dvd.
Nov 23, 2009 | LG 37LH20 37 in. LCD HDTV
Black parts of screen looks light light is shining on it
Your LCD TV uses backlights and they can be slightly visible when viewing a letterbox movie.  However, if the light is really bleeding into the black, there could be a problem, but mosty this is common.
Mar 24, 2009 | Samsung LN-T3253H 32 in. LCD Television
Wide screen lcd simple question.
Hi pooing stone,
You may sometimes find that even with a television referred to as “widescreen,” widescreen movies still have letterboxing.
This is likely because the movie you are playing is still in the ratio used at a theater. While most televisions are 4:3 for the more square-type or 16:9 for widescreen, a theater screen is much wider still. Unless the movie has been reformatted specifically to 16:9 for your television, you will either see letterboxing or lose portions of the picture by zooming in.
If a movie is available in several ratios, I suggest thinking of all the options before buying. Although purchasing a movie reformatted to 16:9 will prevent the black bars, purchasing it without any reformatting of the size will prevent you losing part of the picture.
FYI: It is very common with Blu-Ray Discs that widescreen means original size, not 16:9.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 03, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
TELEVISION
This user manual should help!
http://portablemedia.manualsonline.com/manuals/mfg/wharfedale_international/l15t11wa_l15t11wc_l19t11wa_l19t11wc_l20t11wa_l20t11wc_l19t12wa_l19t12wc_l20t12wa_l20t12wc_l22t11wa_l22t11wc.html
Jan 13, 2008 | Televison & Video
Camcorder Widescreen Recording Issue
THERE IS REALLY NOTHING YOU CAN DO as your settings conflict with each unit connected
Nov 13, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
