Question about Protron PLTV3250 32 in. LCD Television
Power would not come on
My power supply also went out got it replaced for 220 dollars :( Only lasted 2 years hopefully the repair will last longer
    Sergeant:
  • 199 Answers
If you got the same type power supply  for the TFT tv  then it should not burn again unless the ( DC ) current  in the house is unstable
ie if the current is not stable there is a higher chance of the power pack getting damaged .
Try get a power guard for the TV   and see if it will help
thank you
Posted on Sep 29, 2009
My sons Dell Vostro 1500 has a problem with the AC adaptor. It will run the laptop but wont charge the battery. Any help will be appreciated. Thanks,David
If it will run off the AC Adapter but won't charge the battery then odds are it is the battery that won't take the charge and not the AC Adapter's inability to charge anything.
Google "dell vostro1500 battery" and change to shopping. You will see many available knock off battery's starting at 20 dollars.
Although AC Adapters go out too. They last a lot longer than batteries do. Today's batteries just don't last. I would say average life span is a year to a year and a half.
Jan 28, 2011 | Dell POWER SUPPLY Power Supply
TV WILL NOT POWER UP. IF UNPLUGED FOR 30 SECONDS IT WILL TURN ON FROM THE SIDE BUTTON ONLY, NOT THE REMOTE. BLUE LIGHT GOES AWAY AND A RED LIGHT BLINKS 6 TIMES
The most common failure on this set to cause that symptom is the power supply. There are capacitors that fail and you can usually see most of the bad parts just by looking at them. If this is the case the best way to repair the problem is to rebuild the power supply rather than replacing it. Mainly because another power supply will have the same problem down the line but you can rebuild your board with heavy duty replacement parts for far less and have it last longer. Most shops will charge about 125-250 us dollars to do this repair. To do it yourself you need test equipment and soldering supplies. Better to have a repairman do this one. Good Luck, Russmann.
Jan 25, 2011 | Philips 50PFP5332D 50 in. Plasma...
I have a LG LCD TV 42LB1DR-UA for 4 years and I am going on my second power supply. Last one was replaced less than 1 year ago. LG says there has been no recall but I can not see paying $200 per year to...
I had mine for 2 years and the main board went out. Cost 650 dollars to fix. Its been less than a yr and a half and it went out again. Selling it on ebay for parts...
Aug 03, 2010 | LG 42LB1DRA 42 in. LCD Television
Power Supply, Computer wont Turn on
Possible Power supply troubles.
1. Noisy Power supply Fan,,,,,
2. Burnt smell
You can buy cheap Power supplies that will last about a year & half for about $20. Or you can spend up to $100 + dollars.
Make sure you the power supply you pick has at least 300-350 watts or more.
Dec 19, 2009 | Codegen Computers & Internet
My ps3 has been fine for the last 2 years. now i
I have just repaired one that had close to the same prob. The screen would go blue but i could hear it start. I replaced the PS3 power supply and has been running ever since. Hope this helps. Good Luck
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Need new power supply for this tv
I like you last comment. LOL
All brand of TV are having somewhat the same problems.
I believe a law needs to pass to have the TVs last longer than 5 years. I see TVs all the time only lasting 16 months.
This web site has 2 complete power supplies in stock right now. Here's the link:
http://www.shopjimmy.com/catalogsearch/result/?q=TLA-04011C+power
Jun 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
My ILO tv wont come on.
Sounds like you probably should have had a surge protector, Kind of an expensive lesson to learn. 20 or 30 bucks for a couple thousand dollar pay off, but anyway, learn from the mistake and put your computer and stuff on one. Well anyway, most TV's will have a fuse in the main power supply that you can order from allied electronics, or your local radio shack. Hopefully you are lucky and after you replace the fuse the TV comes right back to life, if not, it is an excellent excuse to make a trip to your local best buy. =) Hope this helps,  Funnyguyjake
Dec 31, 2008 | iLO LCT32HA36 Television
Protron PLTV-37 37 in. LCD will not turn on with or without remote comcast provider
The capacitors on the power supply are probably leaking. If you can find a tech who still can do component leval repair he can replace the caps, and not the power board.. Much cheaper
The power supply is under rated and don't seem to last long. Maybe a couple of years... If higher voltage caps are used to repair it the longer it will last.
May 10, 2008 | Protron PLTV-37 37 in. LCD Television
No pic, no sound
Hey Wilt: We had the same problem, for the same model of Toshiba TV. Had it repaired yesterday. Turns out the problem was the power supply (P.C.B). The total cost was $192.66 Canadian funds (taxes and labour all in). Our model was 6 years old, buts its playing like a brand new unit now. Hope this helped ...... Good luck
Oct 26, 2006 | Toshiba CZ32V51 32" TV
Protron PLTV3250 32 in. LCD Television Logo
167 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
