Question about Dynasty DGRSC 36-4G Gas Kitchen Range
Clicking noise when gas is on - Dynasty DGRSC 36-4G Gas Kitchen Range
    President:
  • 1,304 Answers
Visualy inspect your ignitors when this is happening,
in most cases with your complaint the range is doing what it is designed to do
what happens is this , you spark the gas, flame on, you put a pan on the flame, for what er reason the flame is pulled away from the ignitor, it looses ground and immediately trys to relight for safety
since you dont say there is an issue when the gas is off, if i were in your home i would be looking for what is taking the flame away from the ignitor
a blower, hood, installation just some examples
Posted on Oct 10, 2009
Amana counter top gas stove when plugged in start making clicking noise and you can smell gas .
on most, your push down and turn to hi to open gas valve and turn on piezio to light burner. it sounds like you have a knob already turned on . the control under the knob may need replacing. kinda an easy replacement if you get new part. check out repairclinic.com for video(maybe) but for parts for sure. be careful. gas is explosive.
Mar 16, 2015 | Amana Cooktops
Press gas hear noise
Is the clicking sound coming from engine itself or when turning left or right?
Apr 09, 2014 | 2002 Nissan Altima
Will not run o gas
if all other LP devices ok check lines to ignitor if ok and clicking noise bad gas valve if no clicking noise replace board that ignitor hooked to
Feb 02, 2014 | Dometic Refrigerators
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
I would suspect that it is not the valve making the noise. I would bet it is the thermal expansion of the metal that you are hearing. Other than that, I have seen cases where there is a flow control valve, and depending on its operation, when it opens or closes on spring power it will over shoot and make a loud clicking noise as the clutch overshoots. This will usually only be about 2-4 clicks though, and around pool equipment I doubt you would hear much of it. I would bet more on the thermal expansion. Kind of like the clicking noise you will hear after you have parked your car and the engine is cooling down.
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Apr 24, 2010 | LG DLG0452W Gas Dryer
I hear a metalic clicking noise when i step on my gas pedal, why
It could be your CV Joints. To test them, turn hard to one side and hit the gas. If it get's worse you have a bad CV Joint. If not, you may have brakes dragging or a hub bearing going bad. I would start with the CV Joints first, especially if you have more than 60K Miles on the vehicle.
Oct 03, 2009 | 2002 Chevrolet Cavalier Coupe
'Screeching' noise, Gas Dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Sep 10, 2009 | Maytag SDG4606A Gas Dryer
When i press the gas the car gives a rough clicking noise
check engine oil and also check electrical fuses..
Jun 30, 2009 | 1999 Chrysler Concorde
Clicking noise
heatman101
vbmvc
Jan 29, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dynasty DGRSC 36-4G Gas Kitchen Range Logo
80 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal DeAngelo
Jaime Hernandez
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
